Old 02-09-2004, 08:02 PM   #1
Mr. Spool
Mr. Spool is an unknown quantity at this point
j30 lsd performance
If I understand correctly to use my 94 j30 dif, I will need 95 plus axels. My question is what kind of permormance gains will i receive or loose with this differential. I know the gearing is different than an s14 lsd. I will be stock for several months and then plan to go turbo. I do not want to loose to much off of the line and or up high. Any imput would be apreciated. Thanks.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 02-09-2004, 08:05 PM   #2
DuffMan
DuffMan's Avatar
DuffMan is an unknown quantity at this point
Send a message via Yahoo to DuffMan
Gearing is a bit taller, so the car will be a bit slower in every gear, but you'll be able to stay in a lower gear longer. Overall, it will be a bit slower but hardly noticeable.
DuffMan is offline   Reply With Quote
Old 02-09-2004, 08:15 PM   #3
the240sxer95
the240sxer95 is making a name for him/her selfthe240sxer95 is making a name for him/her self
Send a message via AIM to the240sxer95
which vlsd is more ideal?
the240sxer95 is offline   Reply With Quote
Old 02-09-2004, 08:18 PM   #4
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
I have a 95 J30 VLSD and it works fine for daily and drifting. For the type of driving I plan on doing, the VLSD is total weak sauce compared to NISMO/KAAZ/CUSCO/ATS diffs..
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 02-09-2004, 10:58 PM   #5
Mr. Spool
so basicaly its not a huge difference compared to a higher geared lsd. becouse I can stay in a higher gear longer will that make up for the lower gearing.
96' SE Turbo'd
Old 02-10-2004, 05:35 AM   #6
GotDriftS14
GotDriftS14's Avatar
GotDriftS14 has made poor choicesGotDriftS14 has made poor choicesGotDriftS14 has made poor choicesGotDriftS14 has made poor choicesGotDriftS14 has made poor choicesGotDriftS14 has made poor choices
i had a 97 J30 diff in my S14 and the gearing was not an issue whatsoever. the difference in gearing is VERY slight and you pretty much won't notice it. the performance of the LSD was great compared to stock open diff, but compared to a real clutch type LSD the VLSD isn't even close. it's still good for the price though that's for sure.
GotDriftS14 is offline   Reply With Quote
