Old 02-09-2004, 11:30 PM   #1
kongmike
kongmike is an unknown quantity at this point
Send a message via ICQ to kongmike
problems on installing hotshot header
I have asked a mechanic shop to install a hotshot header which I bought from enjuku on my 91 nissan 240sx (s13), but the mechanic told me that there s a clearance problem. Here is what he wrote:
there is a clearance problem with the air injection tube at the header.
the steering shaft hits the tube as the steering is turned, the only way to make clearance for the steering shaft is to relocate the air injection fitting to a different location and reweld the connection.
you may want to call the header supplier and see if another header is available for your car.
the egr tube position is ok. the problem is with the air injection tube. the fitting for the tube is located on the drivers side of the header(this is the correct side for the air injection tube fitting -just the wrong position on the header tube) and interferes with the steering shaft coupler. the upper part of the coupler (upper coupler pinch bolt head) hits the air injection tube fitting when ever the steering is turned. this problem is even worse when the engine is torqued in any forward gear.
Could anyone tell me how to solve this problem.
kongmike is offline   Reply With Quote
