Old 06-11-2012, 04:11 PM   #1
aznsquad
aznsquad is an unknown quantity at this point
how to jump a s14 power window motor
hello, i think my power window motor/solinoid took a crap.
I attached a wire from the positive battery terminal to the 2 wire connector going to the motor (on the passenger side door skin), I tried both of the terminals (1 goes up and 1 goes down) and neither one of them worked.
Am I jumping the window motor correctly? If so, I guess the motor is dead?
thanks!
aznsquad is offline   Reply With Quote
Old 06-11-2012, 04:17 PM   #2
imcunner
imcunner is an unknown quantity at this point
Motor is prob dead
imcunner is offline   Reply With Quote
Old 06-11-2012, 04:47 PM   #3
doitsidewayz
doitsidewayz's Avatar
doitsidewayz is an unknown quantity at this point
Yup. your motor is dead.
doitsidewayz is offline   Reply With Quote
Old 06-11-2012, 10:32 PM   #4
Copilot911
Copilot911's Avatar
Copilot911 is an unknown quantity at this point
Did you remember to attach a wire to the negative battery terminal as well?
Copilot911 is offline   Reply With Quote
Old 06-11-2012, 10:54 PM   #5
ReLiC
ReLiC is an unknown quantity at this point
I don't think you're jumping it correctly. On my old s13 i had to put power to the window AMP. I believe the AMP works the same way as having a relay. I'm not 100% sure if this is right, but i tried different variations in that 2 wire plug (i didn't care about the motor), and i remember i had to put power in one wire, while grounding the other (**NOT SURE**) and switching it around would do the opposite to the window. Again, i'm not sure about this, so don't try it yet. Do a bit more research and you'll find what i'm talking about.
ReLiC is offline   Reply With Quote
Old 06-11-2012, 11:44 PM   #6
twyztidmind
twyztidmind is an unknown quantity at this point
If you look at the plug for the Window motor itself (2 Wires), unplug it from the main harness and run a positive current to one wire and ground to the other. Switching the positive / ground will make it either go up or down.
I have LOTS of S13 and S14 Parts, PM me!
twyztidmind is offline   Reply With Quote
Old 06-12-2012, 07:39 AM   #7
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
Is this your passenger side or driver. If its passenger they dont have a amp so its either u have the windows locked which you should have checked it i assume or its the window motor. If u need a new passenger window motor lmk i have one i can ship it asap.
Old 06-12-2012, 07:50 AM   #8
cmg
cmg is an unknown quantity at this point
This. If you simply run power to one wire the circuit is still open. Blue/red stripe to 12+ and blue to negative is down. Blue to 12+ and blue/ red stripe to negative is up. I do this everytime I drive my car with a electric impact battery.
cmg is offline   Reply With Quote
Old 07-09-2012, 12:03 PM   #9
ontariogreenbeast
ontariogreenbeast is an unknown quantity at this point
...mmmm
......mmmm
ontariogreenbeast is offline   Reply With Quote
Old 07-09-2012, 12:06 PM   #10
ontariogreenbeast
im looking for a passenger side window motor for my 97 240sx. and I noticed your post. Wondering if you still had this part for sale? Lemme know.
