Old 06-24-2012, 10:09 PM   #1
Purestock240
Purestock240 is an unknown quantity at this point
Best headgasket for a KA24E?
running high compression, need the best gasket i can get, any recommendations or reviews? single cam KA
I cant find any copper or all metal gaskets so im not sure what to do
Purestock240 is offline   Reply With Quote
Old 06-24-2012, 10:14 PM   #2
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
I *believe* don't quote me on it, but a twin cam one can be used if you cut off the front timing part. Use the high performance felpro
Avoid cometic
R@ddy is offline   Reply With Quote
Old 06-24-2012, 10:19 PM   #3
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
I used a Felpro on the last KA-T build it was a DOHC but it worked fine.
eek is offline   Reply With Quote
Old 06-24-2012, 10:21 PM   #4
Purestock240
thanks, im looking into using a twin cam block, why not use a twin cam copper one?
Old 06-24-2012, 10:51 PM   #5
Edwin562
Edwin562's Avatar
OEM is always best.
But if your looking for aftermarket, Cos-worth has a Ka HG.
Old 06-24-2012, 10:54 PM   #6
Purestock240
Originally Posted by Edwin562 View Post
OEM is always best.
well im looking for whatever will hold up to 190psi compression, 9.5:1 and 7200rpm all day
Old 06-24-2012, 10:56 PM   #7
Edwin562
Edwin562's Avatar
your planning to drift/race every time your drive the car?
Old 06-25-2012, 12:25 AM   #8
Purestock240
its a trailered race only car, paved 1/3 mile oval track
Old 06-25-2012, 09:17 AM   #9
iveexcaped3
iveexcaped3's Avatar
iveexcaped3 is an unknown quantity at this point
Best bet is said a de hg with timing cut off then high temp seal the front cover. That's what they all use for ka24e-t at 15lbs of boost
iveexcaped3 is offline   Reply With Quote
Old 06-25-2012, 09:35 AM   #10
Purestock240
but are they using a cometic or copper or?
Old 06-25-2012, 09:47 AM   #11
iveexcaped3
Everyone I know uses cometics and that's what I plan on using. I'll be running 20lbs of boost.
Old 06-25-2012, 10:54 AM   #12
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
You can use KA24DE Metal HG and ARP Headstuds on the KA24E. I'm actually doing the same for KA24ET build soon. GL!
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 06-25-2012, 02:05 PM   #13
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Felpro. 305hp ka24e-t, no issues.
di-devol is offline   Reply With Quote
Old 06-25-2012, 10:48 PM   #14
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
I run a cometic and so far I like it, hopefully you do.
zneubauer is offline   Reply With Quote
