Old 07-08-2012, 03:53 PM   #1
ogs14
ogs14 is an unknown quantity at this point
Signal light and hazard light problems
So when I turn my signal light on it turns n all my lights as if it was hazard lights Im not entirely sure what I should be checking for. And when my lights are on at night my rear signal lights stay on as well. Any help would be great I'm horrible at electrical shit too
ogs14 is offline   Reply With Quote
Old 07-08-2012, 06:00 PM   #2
lighter
lighter is an unknown quantity at this point
have you done anything with wiring ur lights?
lighter is offline   Reply With Quote
Old 07-08-2012, 06:28 PM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
WHat? Might wanna explain and type that clearer...
CLICK HERE!!!
Old 07-08-2012, 07:58 PM   #4
ogs14
No I just put in some led bulbs that's all
Old 07-08-2012, 08:04 PM   #5
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
And there we go.
Read up on the difference between the bulbs used for OEM lights vs LED
For Sale #1 | For Sale #2
Old 07-08-2012, 09:05 PM   #6
ogs14
That can't be the problem I just swapped in new bulbs and still the same
Old 07-09-2012, 07:14 AM   #7
lighter
sometimes bulbs cause problems if u dont use the right one.. i learned that the hard way cause i put in an led bulb on my turn signal and it was doing crazy stuff to my dash panel.. and didnt know y.. so i just used a regular bulb
Old 07-09-2012, 09:06 AM   #8
ogs14
O
Yeah I have led in my tails too. And it makes my whole dad panel flash when I signal
Old 07-09-2012, 09:09 AM   #9
Psychomoongoose
Psychomoongoose's Avatar
Psychomoongoose is an unknown quantity at this point
o
yeah i have led in my tails too. And it makes my whole dad panel flash when i signal
what the fuck
As long as you're not a ham-fisted retard there shouldn't be a problem.
Psychomoongoose is offline   Reply With Quote
Old 07-09-2012, 09:36 AM   #10
zooopreme
Trader Rating: (38)
LED bulbs do NOT put out the same power as the standard bulb. The cars way of letting you know a bulb is out or has a lack of power is by flashing sporadically.
Since you have LED bulbs all over, that's probably what's causing everything to not work properly.
If you start using standard bulbs and it's still messed up. Check the wiring every where.
Old 07-09-2012, 08:42 PM   #11
lighter
pretty much stick to regular bulbs makes life easier
Old 07-09-2012, 09:30 PM   #12
ogs14
yeah i switched out my leds for the right bulb type and my car stopped acting up but now the left light blinks faster than the right but its not burnt out cause there new. what would cause that?
