I know Red Line Oil is used by many race cars and I found out a way to save us all some money by using it! Race cars change their oil after every race, but with Redline they change it every other race. Seems like a lot, but their engines go through extremes. My dad uses it and he has a BMW 850ci, which has 12 cylinders in it, for those of you don't know. Bottom line: a base engine for the McLaren F1.
Moving along, the oil is synthetic and costs about $8 a quart. How many quarts does the S14 take anyways? You'll save lots of money if you use this oil, because you don't have to change it until 21K miles. All you'll have to do is change the oil filter every 7K miles. You'll save time and money! You do the math. |
New Title
240 takes 4 quarts with a filter change 3 or 3.5 (not sure) if you leave the old filter in. I wouldn't trust any oil for 21,000 miles. Maybe I'd drive 4k on it, but not 21, thats nuts.
i wouldnt trust changing the oil every 21k
i dont care how much they tested it eather every 3k for me <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> |
#8 |
I'll be the guinea pig for this. Consumer Reports did a test on taxis, I think in NY, and they concluded that you could change your oil after 6K regardless of what brand motor oil you use. That says a lot since those crazy taxi drivers like to do a lot of stop and go.
#10 |
![]() Join Date: Oct 2001
you can order this stuff online. Go to zilvia home page and click on links. Then click on aftermarket products(somethign like that, I forgot what the actual name of it is) then click on the link that is called "myoilpage.com" They sell it for like $7 bucks or something like that.
#11 |
For more information go to:
www.redlineoil.com It's a racing oil and check out the website to learn more. I'm not sure where you could get one, but I could get it here in Modesto, CA. It's called Bill and Gaines or something like that. My dad told me about the oil and dads are usually right about everything. |
#12 |
![]() Join Date: Jul 2001
O.K. lemme let you guys in on something you should allready know. The only thing that goes wrong with oil is it gets DIRTY!!! Why do you think when it goes in it is see through and comes out black as night? Why do you think it uses a filter?? Because all the moving parts of your engine are metal on metal and the friction, no matter how small causes metal shavings to come off of the moving parts. These particals eventually become sludge, a thick black goo that looks like #### inside your motor. The particals become abrasive and chew away at surfaces that are important for keeping oil from leaking. My father in law owns a garage and just had a truck in last week that the guy said he used slick 50 and didnt change the oil but every 15,000 miles and we had the valve covers off and the engine looked like it had a million miles on it yet the odometer had 81,000. Also a friend of mine works at a lube/oil/filter place and changes his oil every week because it is free and his car has 110,000 on it and doesnt burn a drop of oil and when you pull the oil filler cap you can see the engine looks brand new. Don't fall for these gimmicks, don't be lazy and don't be cheap when it comes to the most important material thing you own.
#13 |
PSI, You do have a point. What was that guy thinking about Slick 50? They got sued for selling that stuff because it was no better than your regular motor oil! I know they probably did something to it to make a little better, or they would be out of business, but I still don't trust them.
#16 |
![]() Join Date: Dec 2001
i heard that they tested the redline oil on a BMW M3, and it gained 10hp to the wheels, wow! but still, i don't care what kind of oil i use, i'll always change it at 3000 miles, better to be safe then sorry.
#18 |
Guest
Posts: n/a
i tottaly agree with psi
there was an altima that came in once the guy had arouind 21 k on it it was a 99! he said he didnt think he had to change the oil what a duck even when we advanced the timing the car was a pos we didnt touch it cause the guy woulda wanted some kinda warrenty on it i use mobil 1 tri syn and i still change my ooil before 3k around 2.5k miles |
#20 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from sspikey on 12:30 pm on Jan. 1, 2002
just like those spark plugs that make you gain 16HP? </td></tr></table><span id='postcolor'> Actually he's half right. European Car did do a test on an M3 with Redline oils. They changed out the diff, transmission, and engine oils with Redline products and the car gained 5hp i believe, not 10. And yes this was dyno tested before and after the change with no other modifications |
#21 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from tnord on 1:34 pm on Jan. 1, 2002
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from sspikey on 12:30 pm on Jan. 1, 2002 just like those spark plugs that make you gain 16HP? </td></tr></table><span id='postcolor'> Actually he's half right. European Car did do a test on an M3 with Redline oils. They changed out the diff, transmission, and engine oils with Redline products and the car gained 5hp i believe, not 10. And yes this was dyno tested before and after the change with no other modifications</td></tr></table><span id='postcolor'> thanx tnord, so i was half right. i felt like an ass for a minute there |
#22 |
wow thats wicked. im sorry i was skeptical its just that ive seen too many oils and additives that say they add hp. slick 50,that new octane mix from razo,spark plugs saying they add 16 HP? nice to know though!
#24 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from EVOtekS14bDIFter on 10:35 pm on Jan. 1, 2002
You know I just can't explain it, but before I crashed my Civic, I slapped on a VTEC sticker on the trunk and I gained about 5HPs. Anyone ever have a similar experience?</td></tr></table><span id='postcolor'> i hope you're not doubting the tests done by european car |
#25 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from tnord on 12:42 am on Jan. 2, 2002
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from EVOtekS14bDIFter on 10:35 pm on Jan. 1, 2002 You know I just can't explain it, but before I crashed my Civic, I slapped on a VTEC sticker on the trunk and I gained about 5HPs. Anyone ever have a similar experience?</td></tr></table><span id='postcolor'> i hope you're not doubting the tests done by european car</td></tr></table><span id='postcolor'> Oh, no I'm not doubting you whatsoever. I'm about to upgrade my fluids to Red Line as well as soon as my car needs it, which is soon! My dad mixed one of their products to his coolant and he says that it keeps his engine a whole lot cooler. |
#27 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from EVOtekS14bDIFter on 12:14 am on Jan. 2, 2002
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from tnord on 12:42 am on Jan. 2, 2002 </span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from EVOtekS14bDIFter on 10:35 pm on Jan. 1, 2002 You know I just can't explain it, but before I crashed my Civic, I slapped on a VTEC sticker on the trunk and I gained about 5HPs. Anyone ever have a similar experience?</td></tr></table><span id='postcolor'> i hope you're not doubting the tests done by european car</td></tr></table><span id='postcolor'> Oh, no I'm not doubting you whatsoever. I'm about to upgrade my fluids to Red Line as well as soon as my car needs it, which is soon! My dad mixed one of their products to his coolant and he says that it keeps his engine a whole lot cooler. </td></tr></table><span id='postcolor'> yah, the thing is called red line's water wetter. i'm going to add that to my car as soon as i have a chance, it's been sittin on my desk for about a month now =P |
#28 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from PSI240SX on 9:11 pm on Dec. 30, 2001
O.K. lemme let you guys in on something you should allready know. The only thing that goes wrong with oil is it gets DIRTY!!! Why do you think when it goes in it is see through and comes out black as night? Why do you think it uses a filter?? Because all the moving parts of your engine are metal on metal and the friction, no matter how small causes metal shavings to come off of the moving parts. These particals eventually become sludge, a thick black goo that looks like #### inside your motor. The particals become abrasive and chew away at surfaces that are important for keeping oil from leaking. My father in law owns a garage and just had a truck in last week that the guy said he used slick 50 and didnt change the oil but every 15,000 miles and we had the valve covers off and the engine looked like it had a million miles on it yet the odometer had 81,000. Also a friend of mine works at a lube/oil/filter place and changes his oil every week because it is free and his car has 110,000 on it and doesnt burn a drop of oil and when you pull the oil filler cap you can see the engine looks brand new. Don't fall for these gimmicks, don't be lazy and don't be cheap when it comes to the most important material thing you own. </td></tr></table><span id='postcolor'> Thank god for common sense! I used to know a really nice Mormon woman (not knocking mormons) who cooked dinner for me because she couldn't afford to pay me for working on her car. Helluva good cook. Her car though. She wanted me to change the oil one day, and I said sure, how many miles do you have on it? She says: "I changed it last October." So, about a year with a couple trips to Utah. Now funny enough, 21000 miles is about a year of driving, give or take 10,000. I changed the oil, but at 60,000, her car (90's buick) was eating more oil than my 76 Ford Courier (re badged Mazda 1800 p/u) with 250,000 or so, give or take a million. EVERY 3000 MILES! |
