Old 02-28-2004, 07:46 PM   #1
kapower
kapower is an unknown quantity at this point
will nismo engine mounts work for my ka?
As many of you may know the OE style engine mounts are about
$110 a piece. I don't see the point of paying that much for OE mounts. So heres my question, Will the nismo engine mounts work correctly with the KA?
kapower is offline   Reply With Quote
Old 02-28-2004, 07:50 PM   #2
Pudula
Pudula is on a distinguished road
Send a message via AIM to Pudula
they are the same as KA mounts
Ryan
Pudula is offline   Reply With Quote
Old 02-28-2004, 10:46 PM   #3
Projekt_Sil80
Projekt_Sil80 is an unknown quantity at this point
The nismo mount should be the same for KA or SR you could get them around $250 (2 engine mounts & tranny mount)
Projekt_Sil80 is offline   Reply With Quote
Old 02-29-2004, 12:49 AM   #4
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
I just filled mine w/ polyurethane, I like the results, save the money for a rainy day, thats just my opionion though.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 02-29-2004, 05:28 AM   #5
goodjuan
goodjuan's Avatar
goodjuan is an unknown quantity at this point
Send a message via AIM to goodjuan
the nismo mounts will make your engine sit higher than stock. by eyeballing it, i'd say about an inch and a half higher.
but to answer your question, yes they will work correctly.
goodjuan is offline   Reply With Quote
Old 02-29-2004, 06:23 AM   #6
thx247
thx247 is an unknown quantity at this point
wait wasnt the engine mount for the SR different slightly? I read this a long time ago so I don't remember...but I thought the SR mounts were slightly offset compared to the KA mounts, and thats why KA mounts with SR's were going bad more frequently etc
thx247 is offline   Reply With Quote
Old 02-29-2004, 08:22 AM   #7
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
Yeah, it was like the left engine mount had a slightly different shape.
RedlineRacer is offline   Reply With Quote
Old 02-29-2004, 12:05 PM   #8
thx247
so how is it that nismo mounts are compatible then? Magical bolts?
Old 02-29-2004, 12:15 PM   #9
kapower
Hey mjjstang, how did you fill the engine mounts will polyurethane, and where did you buy it? That sound like a good bang for your buck mod!
Old 02-29-2004, 12:54 PM   #10
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
I've heard they're all the same from lots of people. As for the Nismo mounts making the engine an inch and a half higher, you sir, are smoking crack. When i installed mine, the engine sits maybe 1/4" higher.... MAX. Not something to worry about.
RBS14 is offline   Reply With Quote
Old 02-29-2004, 02:21 PM   #11
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
My KA with Nismo mounts sits a good amount higher. It makes it very difficult to pull off the tranny because it hits the firewall. We had to remove one of the mounts just to get enough clearance. I wouldn't be surprised if mine made it sit around 1 inch higher or even more compared to the originals.
Flybert is offline   Reply With Quote
Old 02-29-2004, 02:28 PM   #12
kapower
The trick to getting the transmission out easly, (Without hitting the fire wall) is to disconect the exhaust at the Catalyctic convertor, and then pull down on the down pipe. That will give you just enough room to manuver the transmission around. Trust me, it makes it much!!! easier! Ok, back to the subject, I think I will go with either solid mounts, or fill my OE mounts will polyurathane. <(Ijust need to know how to do it first???) If my motor sits 1/4" higher it will hit my strut bar. Maybe the old mushy OE mounts are saging? The nismo mounts may position the engine at the correct hieght or somewhere near it?
Old 02-29-2004, 03:19 PM   #13
mjjstang
well As you may know, the mounts have fins kind of like an accordian. you just buy window mold polyurethane caulk, and well the bolts were stripped in my mounts so I had to do it with them in the car, exept the tranny mount Which I did out of the car, basically you just fill the acordian like fins, and basically anywhere that looks good to you, its pretty straightforward once you get in there. I used 2 bottles. and let it dry for a few days, some people say 24 hours, but mine was in the garage with little to no light. I did one first to compare the difference, and it feels a lot stiffer.
Old 03-04-2004, 08:35 AM   #14
sil80drifter
sil80drifter is an unknown quantity at this point
the engines sits higher because old mounts were saggy and... old. depending on how much they have sagged on you, you will notice a large or small difference in new height. the NEW height is the stock height. your OLD height is busted height.
this poly-u filling idea is interesting... did you melt/burn the old rubber out before you filled it with PU?
sil80
sil80drifter is offline   Reply With Quote
Old 03-04-2004, 09:28 AM   #15
nismo2491
nismo2491's Avatar
nismo2491 is making a name for him/her selfnismo2491 is making a name for him/her self
I'm going to custom make solid mounts for my setup. just use a large block of steel and machine out the inside or whatever. The polyurethane thing works great. let me suggest 3m windo weld thats the stuff to use.
KEvin
nismo2491 is offline   Reply With Quote
Old 03-04-2004, 10:58 AM   #16
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
they are hollow inside, i m gonna fill mine with windowweld, i did it to a nismo tranney mount and it works awsome
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 03-04-2004, 06:53 PM   #17
mjjstang
so what you inject it into the mount itself like a syringe. how does that work, the stuf barely comes out of the caulk tube as it is with like a 1/4 inch opening. please inform me. thanks.
Old 03-04-2004, 06:58 PM   #18
ryan hagen
ryan hagen's Avatar
i either have to find a pastry style syringe or make a big hole that i can use window weld and a calk gun
