Old 08-28-2012, 11:24 PM   #1
Zalo
Zalo is an unknown quantity at this point
KA Sputting ka24de HELP
So I got a 89 240sx with a 96 ka24de swap. Everything was running fine untill recently when I noticed the engine rocking a bit more than usual. As a precaution I stopped driving it in hopes that some one would could come help me figure it out. But after several canceled plans and no idea whats wrong I started checking out some forums and started working on little things. After all ive done the problem continues. But I felt a little more comfortable to take it for a drive. Thats when I noticed the sputtering when I accelerate and that my car accelerates slowly like theres a limiter or something. I have no clue.
So far ive done:
A throttle body cleaning
Oil change
(when i checked my oil i was running low which is mostly why i stopped driving)
Put in a new O2 sensor
My thoughts are:
Bad Idle Air Control Valve
Clogged Fuel Filter
Broken Fuel Pump
Bad ECU
Bad or clogging Fuel Injectors
Things ive checked:
Motor Mounts which was my first thought are good.
My Mass Air Flow is clean and not fried.
Problems I had before this one:
Exhaust leak
Idle control (car would cut off when coming to a stop after running for a while)(low idle almost stalling)
Takes a few times to get started after running for a while and resting a bit. (Always clicks doesn't always turns over though)
I don't have any other ideas of what it could possibly be. Im not a pro at this but ive been doing some research and figured it wouldn't help unless I ask myself and explain my unique problem. I would just get all new parts if I had the money. I figure i'd try to get some direction before I go spending money.
Thanks for taking a look and putting in some thought if you do.
Zalo is offline   Reply With Quote
240sx, ka24de, s13, sputtering, swap
