Old 03-03-2004, 09:21 AM   #1
91 240
91 240 is on a distinguished road
Battery/altenator problems.
This is for my 91 240, in which i've just replaced my blown SR. All I did was to pull and replace the motor and I cleaned up the lower harness(new looming, tape, etc)
Here is a previous post of what has been happening recently.
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Since then I've gotten a 1000 mile used SOHC altenator that work for a day then quit. Got it tested and was only pulling 3 volts. Got the battery charged again (4th time) and bought a brand new altenator. It ran good for about 10 miles. I took it to a parts store to check it out to make sure. They brought out their portable battery/altenator/starter diagnostic machine and hooked it up to the battery and the altenator was not charging, 3 amps at idle and 20-30 amps at 2000rpm when it should be 80amps. I pulled the alt. off and had them bench test it, it was charging at 13-14v. Put the alt. back on the car and drove for another 5 miles when the damn thing died again. The fusable link is fine, the 75 amp fuse is fine, wiring seems fine.
Any suggestions???
Thanks
Avery
91 240sx
03 Pathfinder
91 240 is offline   Reply With Quote
