Old 03-07-2004, 06:52 AM   #1
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
I think my fuel pump is bad
My car has a hard time starting somtimes and when I am starting off from a stop, it stumbles. I am thinking that it is my fuel pump. What do you guys think? If it is my fuel pump, I thought about just upgrading to a Walbro. But I think I will run rich. Will I on the stock FPR?
RedlineRacer is offline   Reply With Quote
Old 03-07-2004, 12:02 PM   #2
aeontony
aeontony is an unknown quantity at this point
How are your plugs doing? Do they look corroded or anything?
The fuel pump supplies constant pressure, so it's not something engine dependent. I think if your fuel pump is going you would have strange problems at all times. If you're sure it's a fuel issue, the fuel filter and the injectors are always good to check. I'd pull the injectors and check the spray pattern.
S14.5 for sale. Must move on with life...=(
http://www.zilvia.net/f/showthread.php?t=56822
Au no wa wakare no hajime...
aeontony is offline   Reply With Quote
Old 03-08-2004, 12:06 PM   #3
RedlineRacer
changed the injectors and put in a new fuel filter, spark plugs, plug wires, dist. cap, dist. rotor, air filter, TPS sensor, and O2 sensor. I get my PCV out and clean it. But I don't know how to get to it easily.
Old 03-08-2004, 12:44 PM   #4
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
no you don' need a different FPR to upgrade teh pump (SR for sure) ntoe sur on KA
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 03-08-2004, 01:23 PM   #5
Jimmyg41
Jimmyg41 is making a name for him/her selfJimmyg41 is making a name for him/her self
Maybe it's your starter.
Jimmyg41 is offline   Reply With Quote
Old 03-08-2004, 03:31 PM   #6
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
Walbro (255s anyways) will indeed make you run rich. My SR did the exact thing you're explaining until I got my fuel pressure adjusted correctly (via my tomei FPR).
Originally Posted by the head
no you don' need a different FPR to upgrade teh pump (SR for sure) ntoe sur on KA,
It depends on the pump. I'm only running a S15 fuel pump and I still ran extremely rich until I had my FPR adjusted. I'd have to call shinannigans on your statement man. SRs WILL RUN w/o adjustment, but it'll be far from optimal, and depending on the climate you live in, may run anywhere from basically acceptable to crappy.
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 03-09-2004, 07:44 AM   #7
RedlineRacer
I think you are right on the regulator, because when I fill my car up totally (which I rarely do) it drives so much better. So do I need more pressure to make it run smoother?
Old 03-09-2004, 01:44 PM   #8
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
how about you do some inspecting first, like pull off the fuel feed line and see if fuel is coming out of it. Mine went out last year, and the car would stumble and have a really hard time starting. Everyone was telling me the same things everyone here is saying. But unless you run through a proper inspection, you'll be wasting time and money.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 03-10-2004, 08:19 AM   #9
RedlineRacer
I haven't seen any fuel anywhere. I looked for cracks in my fuel line but I couldn't find any. I tried looking at my line that goes to my regulator, but its too hard to see.
Old 03-10-2004, 12:39 PM   #10
Yoshi
Yoshi's Avatar
This is what a fuel pressure gauge is for
req to tune your FPR anyhow
Old 03-11-2004, 09:24 AM   #11
RedlineRacer
As the RPM's go up, you need more pressure right? Cause around 2k-4k rpms it acts really sluggish, then at 4.5k it acts like it has all this power and will drive smoothly all the way to over 6k. But, below 4k, it acts like it has no torque almost.
Old 03-11-2004, 10:32 AM   #12
crash153
crash153 is an unknown quantity at this point
i never thought i'd hear that problem again... i had that problem with my s13... the plugs need to be replaced, and that's what caused my issues.
crash153 is offline   Reply With Quote
Old 03-11-2004, 08:03 PM   #13
RedlineRacer
I got brand new plugs. Only got like 2k miles on them.
