Old 11-22-2012, 06:43 AM   #1
myndseye
myndseye is an unknown quantity at this point
Borg Warner Turbo / 800hp / $550 shipped
Used S300sx3 ETT 91-79. From the 4 bangers to big 8 cylinder setups, this is the turbo you've heard about. Only about 50 miles
This Turbo has ETT : Extended Tip Technology (ETT. BorgWarner AirWerks turbos employ BorgWarner "S" generation compressor wheels that incorporate extended tip technology. This compressor wheel design feature promotes greater airflow using low inertia wheel that performs like a wheel of greater size & mass.
Compressor wheel - 66.11mm/91.44mm 80lbs/min Turbine wheel - 80mm/73mm Compressor inlet - 4" hose Ported Shroud Compressor outlet - 3" hose Turbine Inlet - Divided T4 .91 A/R
myndseye is offline   Reply With Quote
Old 11-22-2012, 06:58 AM   #2
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
Free bump for a badass turbo. I am going to use this turbo but I bought a t3 070 ar turbine housing from bullseye power. GLWS
Sr22 in the works
slow92 is offline   Reply With Quote
Old 11-22-2012, 10:24 AM   #3
91white_ka
Banned from the Marketplace
91white_ka is an unknown quantity at this point
Where in Alabama are you located? Pm me?
91white_ka is offline   Reply With Quote
Old 11-27-2012, 07:04 AM   #4
myndseye
Bump
Old 11-27-2012, 07:06 AM   #5
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
If my mani was divided t4 id be all over this. bad ass turbo
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
borg 91-79, borg warner, s300sx3, turbo
