Old 12-12-2012, 09:35 PM   #1
acidreian
acidreian is an unknown quantity at this point
The problem that will stump every sr20 guy
Long story short.
1989 240 coupe with a sr20 swapped by zfevor or Florida btw they ripped me off
I drove the car 24 hours before it blew up
The sr20 died out went from bearly idling at a light to dying out then I checked the temp and it spiked up I pulled over shut it off checked the coolant a little bit low no big deal. I towed it back to them said Wtf is this they said oh you threw, rod give us 3500$ and we will start working on it for you I said fuck off towed the car home and started tearing it down turns out the intake cam walked so I got new head new cams put new head gasket on it because it looked bran new I replaced ecu harness ignitor cas plugs I have the timing perfect cas timed dead on but the car wants to start but it dont.
There was no rod thrown the car fuel locked same time the cam walked.
So if I have timing perfect
I have spark
The cas fires each injector the harness is wiring in right I turns over gos blubabuaahaaaa.... Then it cranks over like it's flooded idk what the hell is going on clues?
acidreian is offline   Reply With Quote
Old 12-13-2012, 12:39 AM   #2
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
Maybe the ECU crapped out.?
kojiki88 is offline   Reply With Quote
Old 12-13-2012, 01:02 AM   #3
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
Sounds like a thrown rod.
Are you positive your cas timing is correct.
4x4le is offline   Reply With Quote
Old 12-13-2012, 01:44 AM   #4
Sileighty_85
Sileighty_85's Avatar
did you mil the the new head?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-13-2012, 07:25 PM   #5
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Did you happen to clean the plugs after the first start up try?
godsmack is offline   Reply With Quote
Old 12-13-2012, 09:16 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
This thing will stumped every SR20 guy because of lack of info from you. There's still like a billion things you could check. I'd start with making sure the mechanical timing is good. Then CAS timing. If those are good, I'd do a compression check just to make sure the engine isnt shit.
Remember, all you need is fuel, compression and spark, thats assuming the timing is good.
CLICK HERE!!!
Old 12-14-2012, 05:46 AM   #7
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Try to use a proper grammar, can barely understand what ur sayin.
Flip is right; compression, fuel, and spark is all u need.
I bet ur mechanical timing is still off. Count ur chain links and make sure all the marks are aligned properly. Picture of ur cam gears would help
Luvs2slide is offline   Reply With Quote
Old 12-14-2012, 11:55 AM   #8
spools420a
spools420a's Avatar
spools420a is a well-known jackass
if you milled the head remember stock timing marks will be wrong timing just incase you overlooked.
spools420a is offline   Reply With Quote
Old 12-14-2012, 06:06 PM   #9
Sileighty_85
No it wont. milling doesn't remove inches... only Thousandths of an Inch
後輪駆動車1番
1986 SR86 - 200ish
Old 12-17-2012, 02:32 PM   #10
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
LOL
Maybe you should listen to your own advice.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 12-18-2012, 06:26 AM   #11
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Trolollol u understood it!
