Old 03-25-2004, 11:17 PM   #1
mtbr64
mtbr64 is an unknown quantity at this point
s13 loud acceleration please help me
whenever i accelerate when im in the gears the car sounds like a jet engine almost as if the fan of the car is doing the accelerating. its not the sound of the engine u can hear that faintly ive noticed ive lost alot of performance in my car aswell. when i downshift it does this aswell. please give me your input
mtbr64 is offline   Reply With Quote
Old 03-25-2004, 11:21 PM   #2
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
tranny problems or clutch fan not disengaging?
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 03-25-2004, 11:25 PM   #3
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
big exhaust leak where exhaust manifold mounts to head. Check it out.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 03-25-2004, 11:33 PM   #4
mtbr64
i was told that the sycnro's in my transmission are gone could this be the problem?
also my clutch is on its way out.
could that also be a problem?
also when i drive the car for a long time the sound is less noticable but its still there
Old 03-26-2004, 02:55 AM   #5
s14xman
s14xman's Avatar
s14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of light
Send a message via AIM to s14xman
I just think it is your clutch fan actually turning on, its getting hoter now and they are starting to engage agian, Mine sounds like a UPS truck!!! Try to just remove it by takin off the four bolts connected to the water pump pully, pull the fan off bolt the four bolts back on so you pully doesn't fall off, and see if you still hear it.
FRontline (marinating since 02)
s14xman is offline   Reply With Quote
Old 03-28-2004, 04:03 AM   #6
mtbr64
okay im sure its not the clutch fan
it seems to be loudest in first gear.
when im at a stop light and the car is just idiling it does not howl.
even if i rev the engine .
when i drive and i push the clutch pedal down the noise goes away.
what could be the problem?
could it be the sound of my bad clutch?
syncros?
common guys help me out here
Old 03-28-2004, 05:56 AM   #7
PSI240SX
PSI240SX is an unknown quantity at this point
if your synchro's were gone or bad you would have a grind when shifting into a gear. I killed my 5th gear synchro racing a bike last week and it didnt make any weird noises. It just grinded every time I put it in 5th after that. Sounds like maybe a clutch/throwout bearing problem.
By the way.... I won
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
