Old 04-09-2004, 11:58 AM   #1
Big Burt
Big Burt is an unknown quantity at this point
SR20det oil leak from around the filter
I changed my oil (mobil 1 of course) two days ago and put on the right filter (factory nissan ser sentra). Then yesterday I had a pretty steady drip. So I double checked everything, sure enough everything was tight. I even put a different filter on thinking the other one might have been defective. I think its the bolt on filter base that sits on the block. I've seen a prelude gushin oil from there before. Has anyone ever had theirs leak before and can I just take it off and fix with some rtv, or is there a gasket I can buy somewhere?
Big Burt is offline   Reply With Quote
Old 04-09-2004, 12:57 PM   #2
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
You could try gettina new oil pedelstol thing... also try putting a little oil around the filter when u put it on
speeddreamz is offline   Reply With Quote
Old 04-09-2004, 03:12 PM   #3
element240
element240's Avatar
element240 is an unknown quantity at this point
Send a message via AIM to element240
and make sure there isn't an old gasket stuck onto the filter seat/threaded part thing on the block.
that happened to my friend and oil spewed all over! not to mention he had to buy more oil....
element240 is offline   Reply With Quote
Old 04-09-2004, 05:51 PM   #4
Big Burt
Yeah I know to lube the gasket and always check for the old gasket to come off. I've worked at valvoline for a year and a half and go to technical college for automotive technology. This whole oil leak thing just scares me cause I cant really tell where its coming from. It looks like its coming out around the filter base, but I just hope oils not coming from just north of that where the block and head meet(head gasket leaking maybe?). That would suck fat D. Under the pedestool is there a gasket or something I could replace? Or do you normally have to buy a whole new one. In which case where the hell would I find that, since the ser sentra's is different?
Old 05-31-2010, 07:11 AM   #5
PhopsonNY
PhopsonNY's Avatar
PhopsonNY is an unknown quantity at this point
Old post I know, but wouldn't it be good if we also had more solutions posted here to help other lost souls?
I had to use RTV because there was not time to wait for and order
The part you are looking for is Nissan # 15066-5E510
You will need two of them.
Above!!!
PhopsonNY is offline   Reply With Quote
