Old 04-11-2004, 04:19 AM   #1
sr20d3t
sr20d3t is an unknown quantity at this point
Loud Rear trunk anytips on how to calm it down ?
Hi guys ; ever sinced i gutted my rear (back seats / speaker brackets / spare tire / etc etc) the trunk got louder i was expecting it aswell but didnt quite expect it to be this loud / after i installed the sub frame spacers (T3) i started to hear sqeaking and clunking noises..its pretty loud and i got somewhat used to it but its kinda hard to keep a conversation and especially driving with your gf ..all she does is whine anyhow i love the car its my dream car in the making =) next to my 300zx TT anyhow do you guys have any tips on how i can calm down the rear ? i would love the sqeaking and clunking noise to go away and i cant pinpoint where its coming from..all i can really guess is that it might be my sub frame spacers (installed upper/lower)..anyhow any input would be nice...
sr20d3t is offline   Reply With Quote
Old 04-11-2004, 11:15 PM   #2
DORIMON
DORIMON's Avatar
DORIMON is an unknown quantity at this point
When I got my car, my trunklid was rattling whenever I went over a bump so I found out about unbolting the trunk latch and slightly lowering it a little so that when the trunk closed it would close tighter. As for squeaking, I can't help you there.
DORIMON is offline   Reply With Quote
Old 04-11-2004, 11:38 PM   #3
nismofeind
nismofeind is an unknown quantity at this point
http://www.zilvia.net/f/showthread.php?t=50638
These helped me out. helped with some of the rattles. the clunk got a little quieter too. I have a lot too.
nismofeind is offline   Reply With Quote
Old 04-12-2004, 01:26 AM   #4
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Zenki was right about unbolting & lowering the trunk latch - it compresses the rubber bump stops located on the bottom portion of the trunk lid reducing some of the rattling sound. You might want to try adding some rubber bumpers...something like the attached...
http://www.welovemacs.com/9224503.html
Any hardware store or Radio Shack should carry these bumpers. What you want to do is use the self adhesive on the bottom of the bump stops placing them on the metal frame of the car body/trunk area directly below where the stock rubber bump stops rest on your car body. What the rubber bumpers do is to compress your trunk lid tighter against the car - helping to reduce the trunk rattle. My buddy Jason told me about doing this to help reduce trunk rattle noise.
As for all the other creaks & groans...sounds like the results of a stiffer suspension...you think about putting dynomat down to help reduce the noise?? http://www.dynamat.com/
Anyhow, hope this helps.
Diego
'95 SE
idlafie is offline   Reply With Quote
Old 04-12-2004, 08:44 AM   #5
BustedS13
BustedS13's Avatar
simple answer: get rid of the g/f....
dynamat would just increase weight. i'd put my interior back in before using dynamat, if i was going for weight savings.... but i'm not, so dynamat and full custom interior =P
Old 04-12-2004, 12:14 PM   #6
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Check the wiring harnesses as well. I found a lot of my trunk rattle was the loom whacking the top of the trunk and reverberating in the trunk space.
Maeda is offline   Reply With Quote
Old 04-12-2004, 08:19 PM   #7
nismo2491
nismo2491's Avatar
nismo2491 is making a name for him/her selfnismo2491 is making a name for him/her self
you could be like me going for weight savings and have the only wires that go past where your rear seat used to be activate tailights and fuel pump and no other wires. that might help. I know with my car gutted there is definitely more road noise then before. especially in rain.
KEvin
nismo2491 is offline   Reply With Quote
Old 04-12-2004, 08:32 PM   #8
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
taking stuff out and adding subframe spacers in..make the cabin louder
SilviaDriver is offline   Reply With Quote
Old 04-12-2004, 11:56 PM   #9
Kookaburraz
Kookaburraz is an unknown quantity at this point
It doesn't do all that much for noise but it sure makes it prettier. Pure rubber undercoating.
http://www.andrew.cmu.edu/user/brjones/N%20009.jpg
www.ziptied.com/forum
Kookaburraz is offline   Reply With Quote
