Old 03-30-2013, 11:57 AM   #1
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
A/c with PBM HMIC
Alright, I may be the first do so this lol i'm trying to figure it all out, now
I have found a small enough condenser to be mounted in front of the the latch support or behind it but covering a little bit of the interooler bottom.
But I was wondering about air flow to the rad and intercooler with the condenser in front.
also plan on mounting fans on the condenser to keep it cool and what not.
rwtf is offline
Old 03-30-2013, 07:37 PM   #2
KoukiMonsta
KoukiMonsta's Avatar
U block air flow,temps rise. Try it, get back to use.
@UpshiftEngineering
KoukiMonsta is offline
Old 03-30-2013, 10:25 PM   #3
rwtf
rwtf's Avatar
maybe so but it depends, my car doesnt get to temp anyway, my temps wont rise I have a nismo tstat to keep temps down.... I also thought about mounting it right behind the radiator.
rwtf is offline
Old 03-30-2013, 11:21 PM   #4
4nmscle
4nmscle is an unknown quantity at this point
I don't know where in Ga you are, but I'm in Bama and you are trippin' if you think that car wont get to temp in the heat of summer.
I run a HMIC, Nismo tstat as well. The idea is horrible man. I don't understand why you wouldn't just use a FMIC. The HMIC is already not very efficient. Everything will suffer with the condensor crammed in front of everything.
And mounting it behind the radiator, seriously? Do you have something against doing things the right way, or do you just want to be different?
4nmscle is offline
Old 03-30-2013, 11:33 PM   #5
rwtf
rwtf's Avatar
it hasnt gotten to temp since ive had the car, anywho, mainly I like the boost response, and my front end is already hacked up anyways so doing a front mount would be retarded. And I would just like to figure out a possible solution, if you don't have any ideas then don't post.
rwtf is offline
Old 03-30-2013, 11:56 PM   #6
4nmscle
My idea is to take some advice from someone who does know wtf they are talking about.
Front end cut up. What??
How long have you had the car? If it doesn't get up to temp when it is 95° outside then you have an issue.
The HMIC doesn't make enough of a response difference to even feel. It's in your head obviously.
4nmscle is offline
Old 03-30-2013, 11:59 PM   #7
rwtf
rwtf's Avatar
well still its what I got to work with, thinking about mounting it something like this
rwtf is offline
Old 03-31-2013, 12:01 AM   #8
4nmscle
Fair enough. Let's see what we can come up with.
Is the condensor in between the rad and IC in this pic?
4nmscle is offline
Old 03-31-2013, 12:25 AM   #9
rwtf
rwtf's Avatar
Not in that pic but he did another setup like that with the condenser, I also thought about moving the rad forward about half an inch, that would give me room to mount it in front of the rad.
rwtf is offline
Old 03-31-2013, 12:33 AM   #10
4nmscle
Your definitely going to want it in front of the rad. Condensors need all the cool air they can get to work effectively. I think that would be the best option.
Have you figured out how you will run your lines? Shouldn't be much of a problem, but will have to be custom I would think.
4nmscle is offline
Old 04-14-2013, 10:26 AM   #11
rwtf
rwtf's Avatar
any one else might have some ideas?
rwtf is offline
Old 04-14-2013, 12:25 PM   #12
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
Post a pic of your "hacked up" front end so we have a better idea by what you mean. Then we'll have a gooder idea on the gooderest idears to give you.
in any situation....thou shalt blaze
ShadowMan is offline
Old 04-14-2013, 10:20 PM   #13
rwtf
rwtf's Avatar
I'll try..
But i've thought about moving the intercooler forward to give enough space for a condenser, or moving the rad back.
rwtf is offline
Old 04-14-2013, 11:22 PM   #14
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
I ditched that shitty HMIC for this. Cost a bit more, but I already had the GReddy core laying around.
Plenty of room for a condenser in there.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline
Old 04-22-2013, 08:29 PM   #15
rwtf
rwtf's Avatar
I thought about doing something like that with the pmb one, Just get two 90* pipes and make it sit out more
rwtf is offline
Old 08-15-2022, 10:53 PM   #16
NissanRWD
NissanRWD is an unknown quantity at this point
Yo! Digging up this long lost thread. What did you end up doing? We?re you able to do what everyone says is not possible?
NissanRWD is offline
Old 08-15-2022, 11:58 PM   #17
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Last Activity: 03-09-2017 06:39 AM
It's not possible unless you get some custom set up.
Most people do FMIC if they want to retain AC.
That's what I did.
FaLKoN240 is offline
