Old 04-16-2004, 05:04 PM   #1
mag0093
mag0093 is an unknown quantity at this point
KA Drivetrain noise
I replaced my clutch with the ACT street kit. Everything else with the drivetrain and engine are stock. About nine months after the install i began hearing a clunking noise The noise is like a fluttering one when i let off the throttle but it gradually disappears as the rpms go lower. I had it up on the lift today with the ebrake on and the driveshaft was able to shake back and forth plus make a noise that somewhat resembles what i hear when i'm driving. Any suggestions as to what this could be?
mag0093 is offline   Reply With Quote
Old 04-16-2004, 05:39 PM   #2
SauN
SauN is an unknown quantity at this point
make sure all your nuts and bolts on the drive shaft to the differential are all tight
also check the differential fluid to see if it low or dirty.
SauN is offline   Reply With Quote
