Old 04-17-2013, 01:45 AM   #1
JustS13R
JustS13R is an unknown quantity at this point
S13 Sr20det Parts / some honda stuff
Parts are loc. in Socal...
This a S13 Sr that i had bought an tore down due to signs of lack oil on the main bearings. It also caused scuffing on the camshafts but they have been polished I dont believe they will be a problem...
S13 SR Crank (needs to be turned) 120
S13 SR Stock bore block resurfaced 180
S13 SR resurfaced head (Brian Crower stage 2 camshafts, valve springs , retainers, keepers, valve guides, valves, circuitsport rocker arm stop, arp head studs) 700
SR rocker arm stopers (circuit sports)25
s13 SR ARP head studs 80
S13 SR Timing chain set ( in good shape no markings) 40
S13 SR stock pistons and rods with rings... used 120
S13 SR intake manifold complete (will part out) 120
S13 SR upper an lower oil pan will part out 50
S13 SR coolant tubes under manifold 30
I also have a group of honda parts if interested pm
b16 block stock bore
b16 crank
b16 stop pistons and rods
b16 cam journals (one cap has a stripped bolt)
b16 Greddy timing belt
b16 s80 trans case and around parts from inside
b16 stock camshafts
b16 stock clutch (ok shape)
Gsr injectors and rail part of a harness
Gsr intake manifold butterfly valves
b16 stock intake manifold
b16 random brackets
b16 random sensors
1999 honda civic front Wilwood Disk brakes 12" rotors and calipers (no brackets, lines, pads) new
1999 Honda Civic ex B20vtec 3000 and includes all the honda stuff with it
168,000 miles, grey interior, white, full greddy exhuast, carbon fiber hood 5spd
JustS13R is offline   Reply With Quote
Old 04-17-2013, 02:07 AM   #2
2LiterTurbo
2LiterTurbo's Avatar
2LiterTurbo is an unknown quantity at this point
Looking to trade for some stuff?? PM me
2LiterTurbo is offline   Reply With Quote
Old 04-17-2013, 04:35 PM   #3
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
willing to sell cams outright?
jaysgottaredtop is offline   Reply With Quote
Old 04-17-2013, 07:29 PM   #4
JustS13R
s13-sr20det-parts-some-honda-stuff
Pm's sent...
will trade everything for a clean turbo coupe...
including the car...
Old 04-19-2013, 06:53 PM   #5
JustS13R
someone wants a civic plus parts for a trade
Old 04-24-2013, 08:02 PM   #6
JustS13R
Bump... taking offers on parts
Old 07-26-2013, 10:47 PM   #7
oscarsx
oscarsx's Avatar
oscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-known
bump for a local!
IG: @ozc2jz
oscarsx is offline   Reply With Quote
