acl sr20det main/rod bearings
im in the process of doing a rebuilt and i want to keep the bottom end stock. will acl bearings work with stock rods or should i just get oem bearings. a simple yes or no will be just fine
![]() Join Date: Feb 2009
![]() Feedback Score: 7 reviews
I'm in the process of rebuilding my SR block because of a slight rod knock.
I went with OEM because they offer different and correct grades specifically for the crank and the block. I also went OEM because I had to get another crank... If you don't know yet, here are tips for reading correct grades main/rod bearings. Under the block, rear drivers side (Upper oil pan removed), you will see 5 numbers.. On the crankshaft, you will see 5 numbers, and under it 4 numbers. If the block numbers are; 12112 and crank numbers are; 12134 You simply just add the block and crank numbers, so you will need grades 2,4,2,4,6 for your main bearings. If both your crankshaft, main caps, and connecting rod, rod caps, and the block surface is perfectly fine, OEM is the best way to go since they offer the precise oil clearance when you use the right grades. The 4 numbers on the crank are grades for your rod bearings. Looks like you got some research to do Mr. =p |
#3 | |
#7 |
FRsport have them in stock. Look up "Nissan Genuine Rod Bearing SR20"
and or "Nissan Genuine Main Bearing SR20" and all grades should pop up. Don't make the same mistake I made buying only (4) rod bearings. They are sold seperately, and 4 rod bearings will only cover 2 connecting rods. Buy (8) pcs of grade 1. For Main bearings, they come with pairs. |
