Old 04-28-2013, 09:14 PM   #1
TheNooB
TheNooB's Avatar
TheNooB is an unknown quantity at this point
s14 No power
So recently my s14 lost all power (between the time i left for work in the morning and the time i got back to my car about 10 hours later) and then after about 15 mins of trying to start it, it came back and the car was working fine. Then two days later, I drove it around a little bit turned it off and about 15 mins after that no power again i had to tow home 5 hours after power was lost.(Clock was only thing working when car had no power and it kept resetting to 1:00 every time i took the key out and tried to start it again) Also, when i turn the key from the 1/3 position to 2/3 or 3/3 the clock comes off too. Now two days later i went and bout some new fuses and an ignition relay and changed most of the fuses i thought where possibly part of the problem (eng, alt, batt and a few others) now the car works fine again but i don't know if it was because of the fuse change or because i left time pass again... I also need to install a new starter i dont know if that changes anything. please also let me know if i even need the ign relay. Can anyone help me out i need to fix this asap!!!!!! i dont know how the answers are seen on here but email [email protected] if it doesnt send an answer notification.... THANKS IN ADVANCE
TheNooB is offline   Reply With Quote
Old 04-28-2013, 09:36 PM   #2
Megin
Megin's Avatar
Megin is an unknown quantity at this point
Sounds like you had a battery drain or fuse problem to me. Check your alternator/battery, and grounds, I guess.
Originally Posted by fliprayzin240sx View Post
Oh hey look, people who like Camry coupes...
Megin is offline   Reply With Quote
Old 04-28-2013, 09:57 PM   #3
TheNooB
TheNooB's Avatar
Thanks for the reply, im going to look into that tomorrow i didnt think it was an battery drain because when the power comes back its not faint or anything, and also when i boosted it i never got any power from that
Old 04-28-2013, 10:10 PM   #4
Megin
Megin's Avatar
Hmm, grounds and fuses is all I can think of.
Old 04-28-2013, 10:13 PM   #5
TheNooB
TheNooB's Avatar
ill check em thanks !!!
Old 04-29-2013, 05:13 PM   #6
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Also check and make sure your battery terminals are tight and not corroded.
godsmack is offline   Reply With Quote
1995, ka24det, no power, s14
