Old 06-06-2013, 08:04 AM   #1
joe3180
joe3180 is an unknown quantity at this point
CA CA smog question
Anyone know if a 89 240sx would pass smog legitimately with a ka24de? I just never really noticed what all they check...
joe3180 is offline   Reply With Quote
Old 06-06-2013, 08:33 AM   #2
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
It should as long as all the smog equipment is there and its functioning properly
R@ddy is offline   Reply With Quote
Old 06-06-2013, 08:40 AM   #3
joe3180
Ok. Thanks.
Old 06-06-2013, 08:44 AM   #4
s14SRguy
s14SRguy is an unknown quantity at this point
California you can't shit in your own bathroom without getting a smog ticket.
but these motherfuckers out here around the IE can drive their diesel f350's all lifted getting 10 gallons a mile, some with smokestacks (on a pickup truck lulz). but no im the gross polluter with my turbo 4 cylinder...
if everything is in fair condition on the car you shouldn't have any problems.
s14SRguy is offline   Reply With Quote
Old 06-06-2013, 08:50 AM   #5
joe3180
Thanks. I just get tired of throwing $200...or whatever it will be in a couple months when I get it done...when I could just swap a different motor in every couple years. I just need to get some money together to buy one and this will open up more possibilities than hunting down only a ka24e.
Old 06-06-2013, 10:41 AM   #6
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
do you have an sr or something? i have a friend with a ka24e but no tranny.. that help at all?
Originally Posted by 13esim View Post
I'll trade you my 300ZX and my older sister
my 240 broke down..again
240boi115 is offline   Reply With Quote
Old 06-06-2013, 11:13 AM   #7
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
My friend swapped in a DE to a 89 but was required to take the car to BAR before they would let him smog it since it is not the engine that came with the car for those years. Might wanna check that out as it seems to be hit or miss on that requirement.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 06-06-2013, 11:56 AM   #8
joe3180
Yea sr. is the engine for sale?
ok. I kinda had a feeling about that. I just couldn't remember the name of the agency. Then they certify the engine has everything and maybe replaces the placard or something huh? Perhaps the de might be a last resort then.
Old 06-06-2013, 02:33 PM   #9
LeaS13Zenki
LeaS13Zenki's Avatar
LeaS13Zenki is an unknown quantity at this point
For smog check we check tail pipe emissions, ignition timing- has to be at factory set timing +- 2 degrees, we check your evap system, we check your check engine light if its on it will automatically fail if it does not work it will fail, we check to see all emission equipment is their, for 240sx that would be EGR, AIR injection, PCV, O2 sensor, catalytic converter vacuum solenoids, vacuum lines, gas cap, leaks, no ripped/broken wires ... Basically everything has to be in working order, nothing missing, broken or modified
So if you have a DE it should not pass, tho it can be ok because you swapped a newer motor which you can do but you have to have it cleared through the BAR and a REFEREE station
LeaS13Zenki is offline   Reply With Quote
Old 06-06-2013, 04:11 PM   #10
joe3180
Good info. Thanks. I think I will have to find a sohc (porb end up buying a whole car with messed up paint or whatever) just to save me some headaches and de if all else fails. I just hope I can find one that works well and that I can get everything moved out together easy. If I had a garage to do my first swap I would already know how easy it is or isn't. The only thing that really has me concerned is if all my body wiring is there still on my car and taking out the sohc in one piece if ac lines are present. I would think everything would be fine but I don't think I will know until I try.
Old 06-07-2013, 01:22 AM   #11
skizsystem
skizsystem is an unknown quantity at this point
I got my car smogged with a dohc in an 89 they didn't even notice
skizsystem is offline   Reply With Quote
Old 06-07-2013, 02:55 AM   #12
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
From all the info I have gathered over the years as long as the engine is of the same year or newer and has all of the smog equipment it would have in whatever car it came from. And it has to be passenger vehicle engine to passenger vehicle, truck to truck etc. same class of vehicle basically.
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 06-07-2013, 07:41 AM   #13
joe3180
Ok. Good. So my options are still open. Happy to hear. Should make it easier. Thanks.
Old 06-07-2013, 11:35 AM   #14
Homeboyx
Homeboyx is an unknown quantity at this point
The worse that could happen is that you'll have to make an appointment with the referee for an engine change.
Homeboyx is offline   Reply With Quote
