Old 07-14-2013, 04:48 PM   #1
kilcourse64
kilcourse64 is an unknown quantity at this point
SR20 coil packs, heat shield, gaskets, etc (reasonable pricing)
Was clearing out the garage when I stumbled upon some miscellaneous SR20 items, figured somebody on here could use them.
Set of four Blacktop SR20 coil packs - $50
SR20 heat shield (needed to pass tech in the Northeast) - $10
OEM SR20 intake tract/MAF/aftermarket filter - $25
SR20 exhaust manifold studs, turbo gasket kit, Hallman boost controller heavy spring, vacuum line, plastic T-fitting, brass T-fitting, brass self-threading tap for hotpipe vacuum source, adel clamp, two 2.25" T-bolt clamps, and one 2.50" T-bolt clamp - $25
kilcourse64 is offline   Reply With Quote
