Old 07-29-2013, 08:34 PM   #1
simon240sx
simon240sx is an unknown quantity at this point
Wastegate 38mm or 44mm?
need to put an external wastegate but I do not know what to put between 38mm and 44mm. I have always had a wastegate actuator. what is the difference between the two? what wastegate you advise? I have a sr20det to 15 lbs of boost with a turbo GT2871R. with the external wastegate I'll get a 20psi.
Thanks!
simon240sx is offline   Reply With Quote
Old 07-29-2013, 11:03 PM   #2
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
38mm will be fine for what you need it for
Pinggg is offline   Reply With Quote
Old 07-30-2013, 07:06 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Larger wastegate will help with boot creep but considering turbo size, I agree 38mm will do fine. This will all come down to preference.
Personally, I like larger wastegates.
CLICK HERE!!!
Old 07-31-2013, 02:18 AM   #4
aga
aga's Avatar
aga is an unknown quantity at this point
well, larger wastegates take space and cost money. if you can do your job with a smaller one, do it. generally, you need a big wastegate when you wanna run low boost on a big cc engine. the more boost you run, the less open the wastegate is, so...
the really good thing about an external (when its got a screamer pipe) besides the sound, is that it effectively makes your exhaust bigger ...just by a bit.
aga is offline   Reply With Quote
