No crank/no start...starter wiring help?
Won't crank at all. Everything else works in the car, just not the starter. I've already tested my starter, it works great. So I know it's a wiring issue.
Here's what I've got. Starter wire (black with a yellow stripe) goes from starter solenoid straight to this plug, then after the plug, white goes into the fusebox/fusible links and the black/yellow wire goes up into the main body harness... ![]() Here's my clutch interlock relay: ![]() I also have this plug, does anyone know what it does? Thick black wire and thick brown/white striped wire: ![]() According to the FSM, the white wire that shares a plug with the starter wire should be black with a white stripe, not white. But I don't have any other plugs that would even look close to this or have either a black/white wire and black/yellow wire...help? |
![]() Join Date: Mar 2008
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
So, really mundane suggestion but it fixed my intermittent start issue, did you check the physical clutch interlock switch? My little rubber stopper degraded after 18 years and the hole it left fit perfectly around the switch without actuating the switch.$2.50 fix from your local dealership.
Sent from my SM-N900P using Tapatalk |
#3 | |
![]() Join Date: Jan 2013
My issue was that little blue relay when I had a no crank issue. I would turn the key, 1 click, but nothing else. Starter was perfectly fine and even fired up the day before. Replaced the relay with one from a junk 240 and fired on the first crank
#5 |
It looks like that plug is the one that's SUPPOSED to be plugged into the othir side of the interlock relay.
If not, that's at least similar (without looking) to the pigtail to the starter. |
#7 |
I already tried that, it didn't fit. And the black wire doesn't have a white stripe on it, both plugs for the clutch interlock have a black/white wire, neither are just black.
#8 |
Here's where the wires go from that starter plug...
![]() Black/yellow goes through the main harness to the ignition switch, the only large black/white wire I see is going from one of the relays in the fusebox to the fusible link, none coming from the main harness like the black/yellow starter wire. |
#10 |
All I know is when I had an SR20 it turned over just fine, now it doesn't with the VH45. I didn't change the wiring since then, other than getting a different transmission harness in better condition than my previous one was.
#11 |
I bypassed the clutch switch and now when I hit the ignition I can hear a clicking coming from what I'm guessing is the interlock relay, its coming from the front right of the car, near all the wiring. I took the starter wire (from the solenoid) and wired it to the white wire from the opposite side of the plug (male starter wire to female white wire) and when the battery is grounded, the starter turns over constantly. So obviously that isn't the way to do it, but I'm still super confused as to why I have a white wire instead of a black/white striped wire. It just doesn't make any sense. There's no black/white wire coming out of the harness near the fuse/relay box either. It goes from the ignition switch, through the car, and disappears somewhere along the way.
#12 | |
#13 |
Hey check this thread out. It details the problem and the fix. See post #52 for the fix.http://zilvia.net/f/showthread.php?t=620069
I followed it and fixed my no start issue Last edited by cole d; 04-21-2019 at 02:32 PM.. |
