Old 11-12-2013, 06:03 AM   #1
S13alldayyo
S13alldayyo's Avatar
S13alldayyo is an unknown quantity at this point
Stupid ac question..
When replacing ac O-Rings, MUST you oil them up or do the come pre-oiled (bought them from advance auto parts. I installed all my rings without oiling them, just want to know if I'll be fine.
S13alldayyo is offline   Reply With Quote
Old 11-12-2013, 06:16 AM   #2
SidewaysS13ka
SidewaysS13ka's Avatar
SidewaysS13ka is an unknown quantity at this point
some oils swell up the o-rings, im pretty sure you dont have to with the ac ones. im guessing you put new o-rings on the end of your line?
Leaks,Creeks,Squeaks, and other random problems. Yup you own a 240.
SidewaysS13ka is offline   Reply With Quote
Old 11-12-2013, 06:18 AM   #3
S13alldayyo
I'm installing ac onto my sr20det swap and I just finished doig all the lines, I'm going to install a new drier and expansion valve next. Then do the whole evacuation/freon fill. Just wanted to know if I'll be fine with no oil or if I'll have leaked everywhere
Old 11-12-2013, 08:00 AM   #4
VegasDrifterS13
VegasDrifterS13 is an unknown quantity at this point
AC Orings Do Not Need Oil.
Sent from my SGH-T989 using Tapatalk 2
VegasDrifterS13 is offline   Reply With Quote
Old 11-12-2013, 08:02 AM   #5
S13alldayyo
Alright cool guess I won't be needing to take everything apart again. And one more question. When I change the drier do I have to poor oil in there before installing? Heard the as we'll just want to make sure I do everything right
Old 11-12-2013, 08:16 AM   #6
VegasDrifterS13
If you are evacuating and charging that will be pointless. Just make sure you look up the right PAG Oil to put in it with your R12 or R134. You Must use PAG oil with your Freon!!!!!!!! Otherwise your mission for AC will restart with a new Compressor.
Old 11-12-2013, 08:24 AM   #7
Chaluska
Chaluska is an unknown quantity at this point
i lubed my O-rings last time when i replaced them all, just a light coating of oil to prevent them from nicking during install. but ive seen it done both ways.
Chaluska is offline   Reply With Quote
Old 11-12-2013, 08:25 AM   #8
S13alldayyo
Got it thanks, I already put in the required pag oil in my new compressor
Old 11-12-2013, 08:51 AM   #9
VegasDrifterS13
Yes but when you vacuum the system out and charge it, you will need to inject the Pag Oil while you charge the new freon. Trust me. Im ASE Certified as a Master Tech. If you want it to last, have a specialized A/C Tech Do it for you unless you have all the proper equipment.
Old 11-12-2013, 09:17 AM   #10
S13alldayyo
I'm having a shop do it for me, so I put in the oil for no reason?
