Old 03-09-2014, 03:23 PM   #1
wrxsr20
wrxsr20 is an unknown quantity at this point
clutch pedal adjustment nut?
I may be wrong but isn't there suppose to be a nut there where I can adjust the clutch pedal? My clutch does not grab until the pedal like 80% disengaged. The sr20 motor is in a AE86.
Untitled by stevengarypapania, on Flickr
wrxsr20 is offline   Reply With Quote
Old 03-09-2014, 05:28 PM   #2
derass
There should be a jam-nut there to lock in the adjustment, by keeping the master cylinder rod from turning in that bracket attached to the pedal.
Sometimes there is a flat surface on the rod to turn with a wrench, but you can just take the pin out of the pedal and turn that bracket to adjust. I would take the bracket off completely, add a nut, adjust, then lock it down.
Old 03-10-2014, 03:03 PM   #3
wrxsr20
Awesome dude that worked, thank you! Maybe you can answer another question I have. I need to hook up the green wire on my after market tachometer, it has to go to the negative port on the coil, but I'm not sure where that is. I would guess this is it but I don't know how to connect it if it is. I have read some threads telling me this is what needs to be done but I have not seen any photos to verify if that's the part I need to tap into.
Old 03-11-2014, 05:41 AM   #4
kexuefazhan
kexuefazhan is an unknown quantity at this point
kexuefazhan is offline   Reply With Quote
