Old 06-22-2004, 11:01 PM   #1
95se
95se's Avatar
95se is an unknown quantity at this point
Injen CAE
I just put the injen cold air extension on, but with a K&N filter, not the original one injen gives u with the short ram pipe. Well, it is very tight in the fender well and I'm sure its probably rubbing on the inside of the bumper. I had to pull the ext pipe, where it connects to the adapter where the temp sensor goes into, down a little for the main pipe to fit on the fan shrowd so its not completely flush with the adaptor but the straight hose covers it so I guess its sealed. Has anyone had this problem? Should I put the original injen filter on, would that help? Or is there another filter that is better that would also fit better than the one I have now?
Thanks
95se is offline   Reply With Quote
