Old 05-30-2014, 10:14 PM   #1
Skawski
Skawski is an unknown quantity at this point
s13 Socal 91 5speed hatch w/ suspension goodies
http://sandiego.craigslist.org/nsd/cto/4496318193.html
I have a 1991 Nissan 240sx Hatch for sale.
This includes everything I own for 240s. all extra parts / drift spares including 4 spares w/ tires.
Clean title out of Illinois.
1995 OBD1 KA24DE 5 Speed manual installed - 3 years ago
Exedy OEM clutch replacement (hypersingle i believe) - 3 years ago
Metal head gasket & head resurfaced - 3 years ago
Injen Intake
Egr deleted & Emissions deleted
New plugs, distributor cap & rotor
Stock exhaust w/ cat deleted(test pipe welded in)
Isis Radiator w/ aluminum shroud and 2 Electric fans
150° Nismo thermostat- no overheating ever!
Water temp adapter/sender installed in coolant hose for Water temp gauge
Wiring for Water temp gauge(w/ relays) installed up to hvac vents in dash
5 lug conversion
Function and Form type II coilovers 16click tophat adjustable. W/ front camber adjustment
Hicas steering rack (2.5 lock to lock) w/ new Energy suspension bushings
Megan outer tie rods w/ Tien inner tie rods
Megan Tension rods
Isis rear suspension arms & Solid subfram risers
300zx differential internals installed in a S13 housing(VLSD)
1 set of S14 rims mounted w/ Kumho ecsta tires in great condition
1 set of 300zx "staggered(tt i believe)" drift spares for rear. smaller rims have tires mounted with 20% life left and I have another 2 tires unmounted for spares.
Set of spacers (15mm i believe; not big)
Clean dash no cracks
The car was primed flat black 5 years ago so it is in need of body work / paint.
This car will need work to pass emissions if you plan on registering in CA!!!
I have Spare parts for the car that will also be included.
mint oil pan
2 x tail lights
pair of headlights with motors
sun roof
random interior / dash pieces/buttons
my loss is your gain. This car is track ready with little work.
If you would like more info or history on the car please give me a call.
(847)452-6281
Skawski is offline   Reply With Quote
