Old 06-27-2014, 03:08 PM   #1
soundboy
soundboy is an unknown quantity at this point
Sr20 aftermarket coilpack option
So. Right now. I'm going to put a sr20det and box into a a31 cifero.
Looking to replace the stock coilpacks that comes on the motor from the foreign used dealer.
Right now I'm thinking either
Spitfire coilpacks.
Ls coilpacks with custom plug wires but that would require a aftermarket tuning system. Such as a aem standalone or haltech . Something I'm not planning to use. Is there anything around this?
Aem smart coils.
S15 coilpacks
My build is going to be.
750 cc injectors or id 1000.
Z32 maf.
S15 t28. Or a gt28 typed turbo
And either a mines tuned ecu. (maybe it could work with the ls coilpacks.)
Or maybe a piggyback like a greedy emanage or blue.
Not looking to go all out. 300-320 hp max. It's going to be daily powered vehicle with the occasional sides.
soundboy is offline   Reply With Quote
Old 06-27-2014, 03:10 PM   #2
ultimateirving
ultimateirving's Avatar
Ls coilpacks will fire on a stock sr20det Ecu. You need iridium/platinum plugs. I was able to drive(not boost heavy) fine with the stock settings, but you can get a rom tune and adjust the dwell
You do not need a stand alone.
Z32 with lq4 swap
Old 06-27-2014, 03:13 PM   #3
soundboy
Sweet. Sounds good. Going to email mines and see if it's possible.
What good rom tune you think I can use?
Old 06-27-2014, 03:20 PM   #4
ultimateirving
Ecutunerguy.com did my tune. Been running about 3 years now, he just retuned it for the ls2 coils this February when I did the conversio
Z32 with lq4 swap
Old 06-27-2014, 04:21 PM   #5
Def
Email Mine's? I'm pretty sure they have little experience with LS coil packs and probably don't offer active support for custom S chassis stuff. They were concentrating on GTRs over a decade ago.
S13 Hatch - Goes around tracks quickly
DEFSPORT
