Old 06-30-2014, 08:58 AM   #1
silvia13t14
silvia13t14's Avatar
silvia13t14 can only hope to improve
Send a message via AIM to silvia13t14
Car won't shut off
Hello guys,
I recently had a turbo timer installed and I accidentally pulled on the wires underneath the handbrake. Now the car won't shut off. I disconnected the turbo timer and recently installed a new engine harness. It still won't shut off. Do you know what the problem could be? Thank you
silvia13t14 is offline   Reply With Quote
Old 07-01-2014, 08:23 AM   #2
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
As long as the ignition switch input on ECU pin 36 is ON, the ECU will keep the engine running.
OnTheChip is offline   Reply With Quote
Old 07-01-2014, 05:50 PM   #3
tributesyst
tributesyst is an unknown quantity at this point
great,As long as the ignition switch input on ECU pin 36 is ON, the ECU will keep the engine running.thanks
tributesyst is offline   Reply With Quote
Old 10-15-2017, 10:20 PM   #4
WWWinfernoWWW
WWWinfernoWWW is an unknown quantity at this point
I guess you have to follow wire 36 and see were it could be getting power from 😁
WWWinfernoWWW is offline   Reply With Quote
