Old 07-06-2014, 10:07 PM   #1
wesismyhero
wesismyhero is an unknown quantity at this point
SR power steering bolts to block?
Does anyone know if the Sr power steering bracket mount to the block bolts are the same as the Ka?
wesismyhero is offline   Reply With Quote
Old 07-07-2014, 08:46 AM   #2
jr_ss
The bolts or the mount? If you have both mounts why not measure how far they protrude through the back of the mount, then measure the depth of the hole on the block...
Old 07-07-2014, 08:56 AM   #3
wesismyhero
I don't have both brackets, just the Sr. I need to know if the bolts are the same so I can just order the ones for the Ka and mount my pump.
Old 07-07-2014, 12:35 PM   #4
quickdiversion
quickdiversion is an unknown quantity at this point
I would say they are different because to use an sr pump in a karaoke. You have to take the pumps out of the housing and swap.
quickdiversion is offline   Reply With Quote
Old 07-07-2014, 01:32 PM   #5
jofus228
jofus228's Avatar
jofus228 is an unknown quantity at this point
I used the bolts from my KA for the steering bracket on my SR20.
Edit: I took used bolts from the KA a/c bracket for the sr20 a/c bracket.
jofus228 is offline   Reply With Quote
Old 07-07-2014, 01:36 PM   #6
quickdiversion
He's asking mount
Old 07-07-2014, 02:10 PM   #7
wesismyhero
What I'm asking is if the bolts that mount the bracket to the block are the same.
Old 07-07-2014, 04:30 PM   #8
Agamemnon
Agamemnon's Avatar
They are not.
Different part numbers.
Old 07-07-2014, 04:42 PM   #9
jofus228
jofus228's Avatar
Actually, I think I used one bolt from the KA for the front of the sr20 bracket and bought new ones for the side.
Old 07-07-2014, 07:04 PM   #10
nickswhlos
nickswhlos is an unknown quantity at this point
good, I used one bolt from the KA for the front of the sr20 bracket and bought new ones for the side.thanks
nickswhlos is offline   Reply With Quote
