Old 07-16-2014, 10:04 PM   #1
sean.arnold9012
sean.arnold9012 is an unknown quantity at this point
KA 92 ka24de Camshaft Timing
Hey guys
sorry if this is a repost but I wasn't seeing anything similar.
I took my valve cover off on my ka24de after zeroing it out.
the timing on the passenger cam is a little off.
is there a way to correct the timing on just that cam without having to redo the entire top timing chain from scratch.
Can I loosen the tensioner, lift the chain, and just rotate that one cam, or is that unadvisable.
Any info that help will be greatly appreciated.
Thank You
sean.arnold9012 is offline   Reply With Quote
Old 07-16-2014, 10:17 PM   #2
Chaluska
Chaluska is an unknown quantity at this point
Originally Posted by sean.arnold9012 View Post
Hey guys
Thank You
even if you remove the tensioner you will not be able to spin the cam.. you will need to loosen the gear, remove it, spin the cam where you need it, re-position the cam gear and bolt it back on.
Chaluska is offline   Reply With Quote
Old 07-16-2014, 10:22 PM   #3
sean.arnold9012
ok that's what I thought.
I was just hoping....
oh well I must do, what I must do
