Old 09-27-2014, 11:25 PM   #1
s13_st
s13_st is an unknown quantity at this point
Stripped threads on head. Please help!
I have an sr20 and i accidentally stripped the threads on the aluminum head with the valve cover bolts. What can I do to restore the threads? Thanks.
s13_st is offline   Reply With Quote
Old 09-28-2014, 02:43 AM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Are you talking about the studs that the valve cover bolts to? If so they sell replacement studs but if your talking about where that stud threads into the head then I don't see why a helicoil wouldn't do the trick..just make sure you don't get any metal shavings/foreign objects into the inside of the head.
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
