Old 08-04-2004, 10:32 AM   #1
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
CA18 tranny internals the same as KA24?
I'm seriously thinking about buying a CA soon. I've done some research and found that the SR and KA have the same internals, but what about the CA? I'm just thinking down the road incase I do buy a CA and the tranny goes out.
RedlineRacer is offline   Reply With Quote
Old 08-04-2004, 12:52 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
they share the internals with the ca18et which is a us engine. not sure with a ka though.
this is the type of thing you should go on some datsun boards to figure out
wootwoot is offline   Reply With Quote
Old 08-04-2004, 06:31 PM   #3
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
why thinking about internal being the same?
just swap the bellhousing and your good to go.
F3600 is offline   Reply With Quote
Old 08-04-2004, 07:18 PM   #4
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
gear ratios are different. Engine internals are NOT the same at all. obviously. just to clarify. the transmissions are similar.
andrave is offline   Reply With Quote
Old 08-04-2004, 07:22 PM   #5
AKADriver
AKADriver's Avatar
The CA18DET has the FS5W71C with similar gear ratios to the KA. 5th gear is shorter (closer) but the others are the same. Dunno if the bellhousing swap works like the SR trans, but the "internals" are close.
The CA18DE has totally different gearing.
Old 08-04-2004, 09:13 PM   #6
mutkung
mutkung's Avatar
mutkung is an unknown quantity at this point
Send a message via AIM to mutkung Send a message via MSN to mutkung Send a message via Yahoo to mutkung
no, but it's swapable but you can use CA bellhousing with KA tranny. You can even use KA cluth disc with CA pressure plate. That's what my brother did to his. He got a CA in a 90 240sx.
One after market part = 3 months of Ramen noodles.
mutkung is offline   Reply With Quote
Old 08-10-2004, 04:29 PM   #7
RedlineRacer
cool, so the bellhousing and the gear box will swap with a KA?
