Old 04-17-2015, 03:41 PM   #1
70newport
70newport is an unknown quantity at this point
SR wont start
Hey Guys,
So I have a 1995 nissan 240 with an sr20det in it. It has run great for the last few years. I went to start it the other day and you can hear the fuel pump turn on but it does not crank at all. Any suggestion on where to start. It almost sounds like it thinks the clutch is not being pressed in but i checked the clutch switch and all seems good.
Thanks,
Gary
70newport is offline   Reply With Quote
Old 04-17-2015, 03:57 PM   #2
cotbu
cotbu's Avatar
Start at the starter, maybe the blade connector came off.
Any other sounds like clicking or buzzing?
From a Highly Tuned Note 4.5!!!
Old 04-17-2015, 08:23 PM   #3
KoukiMonsta
KoukiMonsta's Avatar
Did you turn the key?
@UpshiftEngineering
Old 04-23-2015, 10:46 AM   #4
70newport
Cotbu.
I can hear the fuel pump but thats it. no other noises. I know the battery is good as I used a charger on it and even ended up trying a new battery.
Old 04-23-2015, 03:24 PM   #5
cotbu
cotbu's Avatar
Did you check the connections on the starter, check the clutch switch and or the little grommet that actuates the switch. They tend to get brittle and fall apart.
Sent from a Highly Tuned Note 4.5!!!
Old 05-04-2015, 06:31 PM   #6
70newport
I tried to bypass the clutch switch all together to make sure that was not the issue and I checked connections on the starter moter itself. So confused at this point.
Old 05-04-2015, 07:04 PM   #7
ashero2
ashero2 is an unknown quantity at this point
I feel your pain. Im wear you are right now still. im about to get another new battery also. 500 cca seemed short so about to get a 700 or 800 cca. check the starter like he said, also grab a multimeter and check the ignition relay. mine came out bad.
ashero2 is offline   Reply With Quote
Old 05-06-2015, 09:38 AM   #8
TurboTiger
TurboTiger is an unknown quantity at this point
Is 500 cca the recommended minimum for an SR20?
TurboTiger is offline   Reply With Quote
Old 05-06-2015, 10:20 AM   #9
Croustibat
500CCA is way enough, as long as it is not false CCA like you can find on lifepo4 batteries.
Old 05-06-2015, 02:43 PM   #10
cotbu
cotbu's Avatar
One of the last cars I worked on had an issue just like yours. It was the starter, I pulled the starter off the trans, then ran a ground. Turned the key nothing. Tested the power, and trigger. 12v tested the solenoid intermittent. So I hooked back up and it cranked but it was not enough to start it, was like a dead battery. So I jumped it, cranked stronger, and fired up. But wouldn't start on its own.
So I just rebuilt the started with a refurbished unit from autozone. It cranks strong and fires every time now, I even got it to crank and fire with 10.9v down to 9v that's retarded!
BTW, I did clean the brushes but with the solenoid being bad I had to rebuild it, as it was intermittent at best.
Sent from my Highly Tuned Note 4.5!
