Old 05-06-2015, 06:39 PM   #1
ferrero
ferrero is an unknown quantity at this point
SR Sr20 for sale!! 0 mile
I have well into 4700 in the build.
I want 3700 OBO
I will consider all reasonable offers.
Hell I have 1700 just in the turbo and wg alone.
Its a 0 mile sr
Supertech forged 9:1 Pistons
Brian crower stage 2 cams.
Brian crower stage 2 springs
Brian crower titanium retainers.
Fresh 3 angle valve job
New oem valve seals.
Cometic head gasket
Arp head studs
New oem gaskets all round( front/rear main ect.)
New oem rod, main bearings.
The crank was polished and journals where within NEW specs
New thrust washers.
.20 overbore. ( previously scored cylinder 2. Hince the build)
New oem timing assembly ( chain, crank gear, tensioner)
New adj cam gears ( timing set according to the bc cam card)
I'm sure I'm missing a few odds and ends.
But it's basically a full swap.
Missing
Injectors
Turbo mani. ( I have stock one)
Clutch ( I have stock flywheel)
What comes with it.
Assembled long block.
Trans
Ecu
Harness
Turbonetics t3/t4oe dual ball bearing
Turbonetics rg 45 waste gate.
Full set of WG springs I don't Remeber the lbs but there's like 4 or 5
Z32 maf with pigtail
New iridium plugs
Starter
And again I'm sure I'm forgetting a few things
I have all receipts and shit.
Text for pictures!!
Call or text me (386)344-4194
ferrero is offline   Reply With Quote
