Old 06-19-2015, 12:20 AM   #1
Guns_n_butta
Guns_n_butta is an unknown quantity at this point
s14 Urgent help!!! Blew up stock rb25det turbo
Blew up stock turbo, drove about 2 miles home with heavy smoke. Replaced turbo with another stock turbo today but found my wheel completely shattered on the old one! Removed piping and found the pieces running through air filter, intercooler piping all the way to my throttle body! No signs of oil traveling though. My question is how do I know if any made it inside the engine. Started car and it sounded fine except hearing pieces of the old wheel when lightly reving on throttle. Any help would be great! Also any advice on cleaning out intercooler would be greatly appreciated as well! Thanks in advance!
Guns_n_butta is offline   Reply With Quote
Old 06-19-2015, 03:37 AM   #2
red240
red240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the rough
A bore scope would be great if you have access to one, inspect the plugs for damage also for damage
red240 is offline   Reply With Quote
Old 06-19-2015, 05:34 AM   #3
ehhhregartless
ehhhregartless is making a name for him/her selfehhhregartless is making a name for him/her self
You should throw the fmic away. And remove the head so you can check how many pieces are now circulating on your piston heads
www.zeedakay.com
IG: @zeedakay
ehhhregartless is offline   Reply With Quote
Old 06-19-2015, 05:44 AM   #4
Guns_n_butta
Definitely appreciate it guys Where can I purchase a bore scope?
Old 06-19-2015, 06:52 AM   #5
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
Harbor freight sells them, and you can get a 20% off coupon from their email list.
EnnEssEnnKAT is offline   Reply With Quote
Old 06-19-2015, 08:19 AM   #6
Guns_n_butta
Ok cool thanks again Is the fmic unuseable? Or can you clean it out and remount it?
Old 06-19-2015, 08:49 AM   #7
OBEEWON
OBEEWON's Avatar
Pull you plugs, pull injector connects and fuel pump fuse, spread cloth over the engine bay and crank that souldja boy.
Should blow out any chunks you have in there. But you've run the engine already so the damage may be done.
Old 06-19-2015, 11:49 AM   #8
Guns_n_butta
Started motor Sounds healthy Majority of wheel was inside the crippling on hot side of fmic No oil made it through Safe to say I'm good Definitely appreciate you guys !
Old 06-19-2015, 01:05 PM   #9
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
This guy will try anything you guys tell him and that's scary.
Since this is an rb25 turbo, get a magnet on a stick and stick it into the cylinder through the spark plug hole to fish out the bits.
I would love to sit and eat popcorn and watch as you try to do that
Ilya is offline   Reply With Quote
Old 06-19-2015, 04:14 PM   #10
accoupe
accoupe is an unknown quantity at this point
When this happens at work we always drop the oil pan and clean it out also. It's always full of debris. Then do an oil flush.
accoupe is offline   Reply With Quote
Old 06-20-2015, 01:07 AM   #11
ehhhregartless
^that's pretty good advice. You might even need to Seafoam the engine just to make sure you get all the misc debris out
www.zeedakay.com
IG: @zeedakay
Old 06-20-2015, 06:44 PM   #12
lvlanolin
lvlanolin is an unknown quantity at this point
This happened to mine, and thats when I found out the intake wheel was some kind of nylon blend. I clean out my fmic and then replaced the turbo, but I wouldn't use the same stock one because chances are it will happen again, just my two cent.
lvlanolin is offline   Reply With Quote
Old 06-21-2015, 12:51 AM   #13
Guns_n_butta
No I replaced whole new turbo Everything remained on hot side of fmic Went in with a shop vac Clened cup longs and pipes with brake part cleaner
blown turbo, rb25det block
