#9 |
![]() Join Date: Feb 2008
Trader Rating: (34)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 34 reviews
LS motors are cheap and easy. If you're going to go V8 and want power that is "budget friendly" that's the way to go. There is a wealth of knowledge on swaps out there besides our S chassis community. For $400 for a 5.3 or 4.8 from the salvage yard on a motor that bolts up with a kit you can't go wrong. If price is a concern though no V8 swap is going to be cheap.
#10 |
![]() Join Date: Aug 2011
LS fit, so use one. Which one depends on use and budget.
Get a cast iron block for turbo charging (or for cheap). Aluminium for lightness, balance and NA. You need the "right one", as in the one with the correct oil sump, accessories and gearbox. Truck accessories and intake manifold don't fit, so if you go for a 5.3L you will need accesories and manifold from a car. The swap will cost you minimum 10K. You don't want to read that of course, because you were told you could get an engine for cheap and thought it would be the most expensive, but it really is not. Whole exhaust from headers to exhaust tips, mounts, electricals, driveshaft, cooling and on and on. If you don't have that money, you can"t swap. |
#11 |
![]() Join Date: Jul 2005
When I finally go the V8 route, I will be doing a few things special,
1. the front of my car will come off easily so engine swaps can be done easily 2. Automatic transmission for easy driving and best performance / fastest car, no clutch to wear out 3. It will be turbo, because otherwise what was the point Stock engines all day long to swap in and out with ease at 550-600bhp ftw |
#12 |
In my Dodge 3500 I preferred having an automatic transmission, but otherwise I can't relate on choosing it over a manual when it comes to a "performance" car. To each their own I suppose.
#13 |
I am currently piecing together all the parts to do a v8 swap in my s13 coupe. I am putting a small block chevy 350 out of a old work truck in mine. Has flat top pistons, aluminum race heads, mild cam etc... it will be mounted to a th400 with a 3800 stall. The whole swap together has cost me about 6k including everything. Because everyone is buying the ls swaps you can get a old small block for couple hundred bucks and rebuild it for next to nothing, not to mention the simplicity of a old v8 and wiring loom.
#14 |
anything with 8 pistons works
Www.PowerAutosports.com |
#15 |
L20 Vortec 4.8 (iron block)
LM7 (iron block) L33 (truck motor but its aluminum) L33 had 799 heads (same as 243s), and a different cam I think.... Is what I am currently looking at myself. Most likely I will buy the LM7 as just a block and heads if I can find it.
89 S13/2JZ Silvia(Project Phoenix) IG @awrperformance FB awrperformance |
#19 | |
You would have a hard time catching the car in most daily situations, and it would get reasonable fuel economy by using a modern lockup converter and lighter internal components. It will achieve 27+mpg from a V8 powered 240sx automatic at 3000lbs with mostly OEM parts in the engine if I ever do, and make it better by reducing weight of any parts of course. Honestly, stability at high speeds may be the only real problem, as the 240sx is more well suited to the 350 horsepower sr powered engine, than a brutish 650rwhp V8. I feel like 500~ is a most practical maximum for a daily with that sort of weight, but lol when I say it now I have to laugh at what is really practical, a 500 horsepower engine? Sure why not ![]() |
#20 |
Toyotas 1UZ is a solid engine (Its a toyota engine...) V8, lots of reliable power and not super expensive.
Ls is definitely the easy to find economy engine though if thats what youre looking for. |
