Old 08-31-2004, 02:12 PM   #1
rdoggins
rdoggins is an unknown quantity at this point
Send a message via AIM to rdoggins
My baseline Dynorun
Untuned Blue@9psi Red@13psi
90 Nissan 240SX
Redtop SR20DET Swap
24x12x3 FMIC
Stock T25 Turbo
Apexi Twin Chamber BOV
3" Greddy Downpipe
Apexi N1 Muffler & Custom 3" Exhaust
Equal Length Exhaust Manifold
Blowthru Z32 MAF setup
Koyo Aluminum Radiator
Apexi S-AFC
Greddy Profec B Boost Controller
rdoggins is offline   Reply With Quote
Old 08-31-2004, 03:41 PM   #2
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
Nice......
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 08-31-2004, 06:49 PM   #3
TheTimanator
TheTimanator's Avatar
what exactly is that?
Old 08-31-2004, 07:02 PM   #4
Salty_X
Salty_X is an unknown quantity at this point
Z32 MAF located after the turbo but before the throttle body, as opposed to a flow-through setup where the MAF is located before the turbo. It's beneficial for people who run atmospheric blow-off valves, as it doesn't meter air that gets blown off which would typically cause a rich condition.
Salty_X is offline   Reply With Quote
Old 08-31-2004, 07:24 PM   #5
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
i though you'd have a little more power @ 13psi. i'm running 11psi with stock MAF. i thought i had more power
Hi
Var is offline   Reply With Quote
Old 08-31-2004, 07:45 PM   #6
rdoggins
yea I thought I would have more power too
Old 08-31-2004, 10:18 PM   #7
kidinthehall
kidinthehall's Avatar
kidinthehall is an unknown quantity at this point
someone elses numbers with x mods doesnt necessarily translate into your cars numbes with the same mods.
my old setup (stock everything w/ 3" exhaust, FMIC, and 14psi) made 255hp and 250tq.
90 S13:............fitter, happier, more productive.
04 Yamaha R1: 210rwhp on gas/161rwhp on motor
kidinthehall is offline   Reply With Quote
Old 08-31-2004, 10:26 PM   #8
Bradman123
Bradman123 is an unknown quantity at this point
very true, also depends on the dyno used too, some are more accurate then others.
Bradman123 is offline   Reply With Quote
Old 08-31-2004, 09:45 PM   #9
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
What were the a/f ratios? And what fmic do you have?
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 08-31-2004, 09:50 PM   #10
rdoggins
custom 24x12x3 FMIC
didn't have a Wideband plugged in... it was a dynoday(no tuning)
Old 08-31-2004, 10:24 PM   #11
Bradman123
pretty smooth curve, not all jumpy so im guessing the a/f was smooth but i bet ur afc will pull a few more ponies out...i like the 13 psi numbers much better haha. i have close to the same set up, but have a 20x12x3 core, no afc, stock maf. and soon to have a boost controller...even have same year car as you. you should let me know how tuning goes with the safc and what kind of numbers you get then, i was considering getting one.
Old 08-31-2004, 11:30 PM   #12
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
Seriously.
What kind of dyno?
And yooooou neeeed toooooneeeeeeeeng :P
kazuo is offline   Reply With Quote
Old 09-01-2004, 07:58 PM   #13
kidinthehall
If the car was dyno'd on either a mustang or dynojet the "some are more accurate than others" thing doesnt really hold up. and that looks like a dynojet graph to me.
the curve looking so smooth is also an option in the software........a "smooth" curve doesnt necessarily indicate anything without knowing how the dynos been setup
Old 09-02-2004, 06:52 AM   #14
rdoggins
unfortunately the current setup won't see tuning... I'm in the process of buying a GT25R(GT25/40r) and 72lb injectors. That is the setup that'll be tuned in. I'll post new charts when that happens. Should be in Sept sometime...
BTW - My turbo was gone on the above pulls. It smokes like a big dog. I don't see full boost until 3800-4000rpm. I think that has something to do with it. I have a very clean stock T25 turbo that I was going to throw on in the meantime but I figured if I replace the stock turbo I might as well upgrade... Taking these things off in the car proves to be a B!tC#!!!
Old 09-02-2004, 09:36 PM   #15
kidinthehall
its far easier to replace the turbo by removing the manifold. its not even possible to do it with it in the car with a stock manifold. at any rate, its only about 15 mins work to pull it all anyway.
Old 09-03-2004, 06:45 AM   #16
rdoggins
yea give me a little insight on how you remove your manifold, turbo, coolant lines, oil lines, vacuum lines & exhaust in 15 mins...
Old 09-03-2004, 04:33 AM   #17
Blues13
Blues13 is an unknown quantity at this point
Damn, 15 min to pull the manifold and turbo..? Sure buddy.. where were you when I replaced my turbo-mani gasket?
Blues13 is offline   Reply With Quote
