Old 11-06-2015, 12:03 AM   #1
DemonS13
DemonS13's Avatar
DemonS13 is an unknown quantity at this point
RB20DET Misfire Thoughts
Hey everyone,
Recently I did a conversion on my Silvia from a Ca18de to a Rb20det manual. Now I'm just kind of working out all the little issues with it, and getting my head around the Rb.
It is idle hunting (hot days worse than cold) and it is also misfiring (from what I have found, only one cylinder no.4 is doing it). It pulls when it drives due to it, except when it gets over 3000rpm or hits boost. (My blow off is currently running to atmosphere, and the turbo has seen better days since it is loose and always slightly open and blow off is leaking. Not connected, but you never know).
I have done so far the following to no avail:
Tested another igniter.
Replaced the coil packs with new ones.
Changed the spark plugs from platinum to regular and gapped (someone told me that RBs are occasionally picky).
Checked for vacuum leaks . None that I can find (except for blow off), although I am getting new hoses since a lot of them seem to have had their run.
I am currently running a Mines computer, and a stock one is coming soon, although I would assume that if it was this, it would misfire off all and not systematically off of one? I am also soon getting a coil pack harness loom.
I just thought I would ask in case anyone knew of anything that I could do while I am waiting for these to show up, or if anyone has any experience with this issue and how they resolved it.
Cheers Guys
DemonS13 is offline   Reply With Quote
misfire, rb20det
