Old 11-06-2015, 12:46 PM   #1
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Smile 1999 Corvette LS1/T56 $9000
-The issue below has since been fixed. I am keeping the info there so you know the history of the car.-$11k OBO.
Video of the car: https://youtu.be/ORL8GJF6X7w
The new throwout bearing that came with my monster clutch is starting to fail and will make some crazy noises at random times. I am not taking the transaxle back out. I am willing to accept my losses and sell it for this cheap. Clutch and flywheel and all hydraulics are still brand new.
The car still runs fine and accelerates through the gears. No pop outs or transmission issues. Just annoying dying cat throwout bearing noises that come and go randomly. (NEEDS TO BE REPLACED)
Contact Info:
Absolutely no trades, need the money to pay off my new car.
559-765-8363 - Ricky
This car passes smog with no problems. It also is up for registration and will NOT need a smog. I will get the new tags for you and you will be smog free for a year.
About the Car:
1999 Chevrolet Corvette. It has low mileage and runs great, its a clean title in my name. Just barely passed 100000 miles. It is a 6-speed.
Oil changes are done religiously, just did one 10/15/2015, clutch and all hydraulics are brand new, etc. AC ice cold. Heater hot. No fluid leaks(oil, coolant, etc).
Tranny and diff fluid were just flushed also.
Aftermarket Parts:
Column lock bypass kit (important on these c5's)
Tick master cylinder (needed on GM LS1 cars. $304.99)
Tick speedbleeder
New header collector studs (replaced when I did the clutch)
Monster Stage 2 clutch (new, $815)
Monster 18lb flywheel (new)
New throwout bearing
New pilot bearing
New rear main seal
New slave cylinder
New oil pressure sending unit
Zip corvette doorhandle scratch protectors
MSD plug wires
Flowmaster exhaust
Sure I'm forgetting some stuff
CONS:
- It will need new rear tires soon! Also the climate control light is dim..common issue on these C5's.
- Paint is not perfect and plastic top is starting to get sun damaged. Front bumper looks to have been repainted if you look closely. (16 year old car.)
- Interior is a 7/10.
CLEAN TITLE - In my name. Ready to go.
$9000
Located in Fresno, CA
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
Last edited by StryfeS13; 02-18-2016 at 11:54 AM.. Reason: Fixed the issue with the clutch.
StryfeS13 is offline   Reply With Quote
