Old 09-07-2004, 04:45 PM   #1
cys19
cys19 is an unknown quantity at this point
s14 Koni yellows
I read on http://www.carreview.com/PRD_2162_2880crx.aspx that someone bought Koni yellows and the rear could only be adjusted when taken out. Is that true for a 1995 S14?
ALso, I'm looking for a place to buy adjustable damping shocks/suspension in general for cheap. Where do yal usually look into? Thanks.
cys19 is offline   Reply With Quote
Old 09-07-2004, 05:47 PM   #2
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
true for 95-98 models also
this sad truth holds me back from switching to these excellent shocks. To adjust the rears you have to take the coilover assembly out, take the spring off the shock, compress the shock to the bottom and twist. Re-assemble. Test drive. Repeat as necessary
Hi
Var is offline   Reply With Quote
Old 09-07-2004, 06:00 PM   #3
mike13
mike13's Avatar
mike13 is an unknown quantity at this point
Send a message via AIM to mike13
dont AGX's have an external adjustment?
mike13 is offline   Reply With Quote
Old 09-07-2004, 06:17 PM   #4
TheTimanator
TheTimanator's Avatar
yes they do but IMO Koni's are slighty better plus it's another option for people.
The adjustment is not an issue on S13's correct?
Old 09-07-2004, 06:19 PM   #5
AKADriver
AKADriver's Avatar
Adjustment is the same for both. External front adjustment at the top of the strut, internal rear adjustment.
The rear Konis can be rebuilt and coverted to external adjustment, but once you've paid for all four plus rebuilding the rear two, you're up to about the same cost as a Tein SS.
Old 09-07-2004, 07:13 PM   #6
cys19
So where do you guys recommend buying suspension parts? I've been looking into hopupracing but it's down.
