Old 05-17-2016, 03:08 PM   #1
Male
Male is an unknown quantity at this point
SR20DET questions
Hello i have an s13 sr20det red top i believe, I'm getting it bored out to 87mm because i had some wise pistons laying around. I was wondering if i needed a certain sized head gasket because of this? and i was also wondering the benefit of having a thicker head gasket. I'm not planing to build something crazy I plan to keep it mostly stock
Male is offline   Reply With Quote
Old 05-17-2016, 06:38 PM   #2
Mcflurry
Mcflurry's Avatar
Mcflurry is an unknown quantity at this point
You can talk to your machinist reg the headgasket, they will likely be able to modify a metal head gasket to suit your new bore. Thicker is bad for a number of reasons.. quench etc it can have the same negative impacts as reducing thickness and more. Are your wise pistons lower comp?
Mcflurry is offline   Reply With Quote
Old 05-18-2016, 10:53 AM   #3
Male
they raise the completion 9:1 i believe
Old 05-18-2016, 11:44 AM   #4
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
Well yeah, your head gasket is going to have to bore match the Pistons.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 08-28-2016, 12:05 PM   #5
Male
Okay i have all the pistons in I'm wondering what would be a good thickness on the head gasket? they are 87mm wise pistons on stock rods.
Old 08-28-2016, 12:52 PM   #6
cotbu
cotbu's Avatar
You don't get a head gasket base on that!
You get a head gasket based on bore and what is removed from the block and or head.
You might want raise, lower compression but it's still based on that.
And you are not mostly, slightly, or a lil bit stock anymore, after you bore the block!
Old 08-28-2016, 01:14 PM   #7
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
87mm-87.5mm head gasket will be fine, as for thickness it depends on deck height. 1.2 is generally fine in most applications 1.5 is good for if you need more.
As for boring head gaskets only certain designs are bore-able.
[email protected]
hanzbrady is offline   Reply With Quote
Old 08-28-2016, 04:49 PM   #8
jedi03
Yup...the fire ring is what needs to match...can't bore that out as it needs some overlap...I think Tomei had a good list of what sizes match what
Old 08-30-2016, 12:43 AM   #9
cotbu
cotbu's Avatar
Direct bore fit or larger will work. Normally, .5-1mm makes sense, somewhere sombody says 2mm.
Old 08-30-2016, 07:32 AM   #10
jedi03
im using a stock on .5 over...no issues yet...
Old 12-08-2016, 03:53 PM   #11
Male
Hey guys is there any links or formulas that will say how thick the head gasket would need to be to lower the compression back stock or close? I would like to use the stock ecu without having to tune it ... if possible.
Old 12-08-2016, 04:24 PM   #12
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Doubt it will affect ecu
Old 12-09-2016, 07:32 AM   #13
jedi03
I think tomei had one that I used to determine bore...the cr is what you want to calculate to determine gasket thickness that you want
Old 12-13-2016, 09:43 AM   #14
Male
http://www.tomeiusa.com/_2003web-cat...asket_crc.html
Found it! thanks! Also the goal is to get it back to original compression ratio correct? Im wanting to use the original turbo, the higher compression will only be beneficial for a bigger turbo correct?
Old 12-13-2016, 11:56 AM   #15
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
The goal is whatever you personally choose it to be as far as compression ratio is concerned but generally speaking a lower compression ratio would be better for higher boost levels. Was your motor previously damaged or something, causing you to do all this? If not this seems like a lot of trouble just to essentially stay stock. Also, why not replace the rods while you're at it?
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 12-24-2016, 10:19 AM   #16
Kamronman
Kamronman is an unknown quantity at this point
Just know that the thinner the h/g, the higher compression. Typically a 1.2mm thickness is pretty thick, (runs the risk of blowing faster than a thinner one, BUT gets you closest to stock compression). Also, just because you bore out 1mm, doesnt mean your ecu wont run the car right. It will run perfect, no dofference will be noticed I promise! Maybe a few hp naturally but not lean running or problems I assure you. And as for bore on the headgasket. ONLY run a head gasket .5mm wider than your new bore. This is from Apexi. If you do 87.5mm bore on the cyls, do 88mm headgasket.
G/l homie. Its gonna sound great after rebuild.
Kamronman is offline   Reply With Quote
