Old 12-13-2016, 02:40 AM   #1
wild7driftboy
wild7driftboy's Avatar
wild7driftboy is making his/her stupidity well-knownwild7driftboy is making his/her stupidity well-knownwild7driftboy is making his/her stupidity well-knownwild7driftboy is making his/her stupidity well-known
2003 gs300 bagged on ag wheels $5k firm
2003 lexus*gs300*
143k miles
Millennium silver
black leather interior
$5000 firm
located in central california
Interior
Black glitter shift ****
(s)Junction produce front curtains*
(s)bellezza rear curtains
Exterior
Greddy front lip*(broken now still have it if wanted)
Admiration side skirts*
Oem aristo*window*visors*
Roof spoiler
6000k fogs and low beams*
Yellow piaa high beam/daytime*running lights
Led interior lights
Led*reverse lights
Leg*license*plate*lights
Suspension
326power negative camber rcas on mooglower ball joints*
New moog tie rods*
Battle version toe arms*
Tc sportline rear upper control arms*
Bc racing coils (originally 16k front and 18k/ still have all original parts) but are replaced with uas air springs
Air suspension (about 4k invested)
¼ inch air line*
3/8 air line used from manifold to tank for faster fill time
UAS aerosport bags front and rear*
Uas upper billet bag bracket/ top hat*
Uas billet lowerbag brackets front/rear*
Custom rear top hat extension*
Custom rear upper bag bracket*
Avs aluminum 5 gallon air tank*
(2) 480c viair*compressors*
200psi compressor pressure switch*
80amp*solenoid*replaces the (2) relays forcompressors*
Accuair vu4*manifold*
Avs 7button switchbox*
External*schrader*valve*for releasing/drain
(2) smc 3/8 water catchers*
(2) smc check valves
Dakota digital*gauge with (5)*pressure sensors*
All dot approved brass fittings*
All dot approved airline used
Wheels/tires ( $1600)
•*Avant*Garde*m510*bespoke in gloss white*
Billet Candy red center caps
19x9.5 +15
19x11 +18
Federal*tires*
225/35/19 front
245/35/19 rear
Cons: check engine light on P0420
Needs alignment sometime in the future
Needs a muffled hanger
Would go through the rear bushings
will post more pics upon request*
wild7driftboy is offline   Reply With Quote
