Old 01-02-2017, 11:46 AM   #1
chrisbmx68
chrisbmx68 is an unknown quantity at this point
F.S. 08 mazdaspeed 3 73k tasteful mods
73,xxx k miles
$10,000 or best offer
The car is in really good shape, the interior and exterior are clean. The car has no issues and has been well maintained. I am the 3rd owner and have the clean Carfax and all paperwork from the previous owner. I purchased a Nissan Xterra and need to sell my "fun" daily driver.
Exterior
Black painted stock mazda badges on hatch and grill
"frenched" fogs with laminx film
Drop in 4000k hid kit with slim ballasts in stock projector housings (excellent cutoff and beam pattern)
Led license plate bulbs
Hella dual horns mounted behind grill
Interior
Cobb black polished delrin shift knob
Stock color temp brighter led map light bulbs
Lifetime satellite radio subscription tied to the head unit
Suspension
Godspeed mono max height and dampening adjustable coil overs only 10k miles on install
Adjustable sway bar end links on the front
Moog all metal grease-able end links in the rear
JBR 1.25 rear sway bar with optional billet brackets
Ford focus electric rear motor mount firmer than stock and less prone to failure without the NVH associated with poly
Engine
Brand new timing chains and VVT sprocket, as well as serpentine belt idler. I thought there was a VVT rattle but it turned out to just be the idler pulley ugh.
Treadstone 3 inch FMIC
Generic piping kit with T bolts and Murray constant tension clamps
Turbosmart recirculated piston style bypass valve
Newer 2010 Gen 2 turbo with 50k on it swapped in with oil restrictor bolt to prevent the common smoking at idle issue these cars often have
Autotech HPFP internals
Catless 3 inch stainless bellmouth downpipe
Stock exhaust with 3 inch to 2.5 inch adapter for downpipe
Exhaust Tip extended 1.5 inches at the rear bumper to reduce sooting
Accessport v3 with tweaked cobb stage 3 tune for no cat, and scaling for intake 18-21 psi peak
3 inch JBR aluminum wide path intake with integrated maf housing and honeycomb screen
AEM dry flow filter
EGR delete plate
Other
All the stock parts I have will be included with the sale. That includes stock intercooler, two keys, downpipe, bpv, engine cover, shift knob, suspension, hpfp, etc.
chrisbmx68 is offline   Reply With Quote
