Old 02-10-2017, 02:12 PM   #1
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
Angry Turbo Rebuild Roadblock
Hello everyone,
I am in the process of rebuilding my ISR RS3871r turbo. I have done everything except for the turbo oil seal on the hotside. For some reason, I just can't seem to get the turbine to want to go into the CHRA. It's almost as if the seal is too big. Do you think the seal is the wrong size, or do I have to hit it with a hammer really hard or something?
Thanks,
Evan
apex128 is offline   Reply With Quote
Old 02-11-2017, 10:51 AM   #2
PoorMans180SX
PoorMans180SX's Avatar
Sometimes you have to use a pick and compress the ring a little so the turbine slides in. Given that the isr is a knockoff Garrett, it could use different spec parts. Best of luck.
Oh, do not hit the turbine hard with a hammer.
Old 02-11-2017, 11:51 AM   #3
apex128
Thanks for the reply. I did figure out the issue this morning. I had put the thrust washer in upside-down. That's why you don't try to learn new things when are tired lol.
Sent from my 831C using Tapatalk
Old 08-22-2019, 02:54 PM   #4
alexusbailey_s13
alexusbailey_s13 is an unknown quantity at this point
How is this holding up?
Sent from my SM-G973U1 using Tapatalk
alexusbailey_s13 is offline   Reply With Quote
boost, isr, rebuild, s14, turbo
