FS: 93 240sx 2JZ-GTE Single Turbo
Price: $10,500 Contact: [email protected] or text only (909) 587-5075 2JZGTE Engine R154 transmission 1JZGTE Flywheel new Precision Billet 6265 Ball Bearing S Cover T4 divided 1.0 Sound Performance T4 Quick Spool Valve Stage 4 Six Puck clutch from Clutch Master as well as flywheel new clutch hub rings crawler thrust upgrade Haltech Sport 2000 Standalone Mild port and polishing on head (done when rebuilding the head) Haltech boost solenoid Haltech custom wiring loom Aluminum koyo style radiator dual slim fans 12" All line are Earls stainless steel braided lines ARP Headstuds AEM Eugo Brian Crower Cams 272's HKS style fuel rail Precision 1000'cc injectors 6an stainless steel lines fuel lines Ebay turbo manifold (proven to be good, check supra forums) Twin Walbro's GSS341's 3" turbo back exhaust 4.5" muffler all new during swap: genuine toyota parts, headgasket, timing belt, timing tensioner, gaskets 18" KCS 100 absolute fuel filter DNA Cam Gears DNA 13 row oil cooler with filter relocation 4x14x32" front mount intercooler 2.75" intercooler piping Greddy style intake manifold Godspeed 80mm throttle body LS7 Ignition system 5 lug conversion Complete earls stainless steel brake lines z32 1 1/16" master brake cylinder Z32 complete aluminum 30mm calipers and pads Aeromotive FPR Zerolift Motor mount kit TDF drive shaft 3.69 final drive with LSD Upgraded 5 bolt axles Godspeed full coilovers Godspeed tension rod Godspeed traction rod Godspeed camber kit Dakota Digital SGI-5 speed signal INTERIOR: Stock seats 3in harness with pads Godspeed 6pnt Rollcage Godspeed Cross Bar Dynamat from the firewall back to the end of the front seats/start of the rear seats Pioneer Double-Din Stereo and Speakers with dual 10" subs w/ amp. Very nice clean crisp sound, professionally installed BODY: 2009 BMW Metallic Gray Paint All body lines match JDM Silvia front end S13 GT-R Grille Clear side markers and blinkers from Japan purchased from Nissan brand new JDM 180sx Rear Lights TRA Kyoto Rocket Bunny wing Original JDM Aristo weighted shifter Black 350z wheels BMW Style windshield (has a very slight redish hue when the sun hits it at certain angles, looks very clean) SECURITY: Full GPS tracking with dual back up battery and a FM beacon along with direct message to cell! Viper 3303 2-way alarm system (door actuators installed as well full auto lock) Pizzo Siren, tilt sensor, glass break microphone sensor. Cons: Exhaust leak One of the engine mounts bent/cracked. I had it fixed but the engine still doesn't sit completely straight. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by av240s13; 03-21-2017 at 10:34 AM.. |
240sx, 240sx 2jz, 2jz, 2jzgte, s13 |
