Old 10-14-2004, 09:40 AM   #1
240niz
240niz's Avatar
240niz is an unknown quantity at this point
Angry Headlight headache
Here's my situation....My left headlight remains on even after I turn my lights off. I pulled the fuse for the left light and the light is still on. I then pulled the fuse for the right side and guess what, it went off. I put the fuse back in and the left side went back on. I pulled it off again and left it out until this morning. I put the fuse back in and the light remained off. Any info would be helpful. It's a 93 coupe.
240niz is offline   Reply With Quote
Old 10-14-2004, 10:46 AM   #2
Pancor
Pancor is an unknown quantity at this point
Did you check the relays, or is that what you meant by "fuse"?
Pancor is offline   Reply With Quote
Old 10-14-2004, 05:39 PM   #3
NofxareforKids
NofxareforKids is an unknown quantity at this point
Have you installed a new radio or anything electric that isnt stock, i had problems with my headlights staying on when i installed my radio because of the auto dimmer for the display being linked to the headlights also you may want to check the wiring you might have a short somwhere in between the fuse box(or relays) and the actual headlight if you cant think of anything else take it to a shop and heave em hook up a computer to it , theyll tell you whats wrong for a few bucks its usually worth it, if that fails poke it with a stick lol
NofxareforKids is offline   Reply With Quote
