![]() Join Date: Nov 2006
![]() Feedback Score: 6 reviews
My kouki s14 rebuild
Most of you already know my car so I won't go through the previous stages it's been in.
Here's how it looked in March of 2016. ![]() ![]() ![]() Leaving a Nissan get together my timing chain decided to break (it was an LS2 chain, not stock LS1). Not sure why but, that was the last time I drove the car. Timing chain broke, bent a ton of valves, hit the pistons & to top it off a lifter turned in the bore, broke & got stuck which ruined the cam. ![]() ![]() ![]() ![]() ![]() I was upset & didn't know what I wanted to do.....until I did, go bigger & badder haha. I decided that another LS1 with just a set of ported heads wouldn't be enough, after 6 years of a bolt on, cammed LS1 I wanted a lot more power. It was time to turbo the car. A friend found me a used 5.3 iron short block for what was almost highway robbery ($130). New setup is gong to be. gen 3 5.3 iron block gen 4 5.3 pistons & rods new rings, bearings etc for the short block arp head bolts PRC stage 2.5 ported truck heads LJMS stage 1 TT cam Mcleod twin disc Tial 44mm wastegate 80lb injectors Walbro 450lph fuel pump etc etc PRC stage 2.5 truck heads ![]() ![]() Mcleod twin disc ![]() Before I pulled out the old 5.7, I dropped the car off with my fab guy to build the turbo kit while the 5.3 stuff is at the engine shop being rebuilt. Turbo kit is a forward facing truck manifold on the driver side & an LS2 C6 Corvette manifold on the passenger side in order for the crossover pipe to clear the oem GM a/c compressor in its stock location. I was not going to give up a/c in Florida. Frame had to be notced for downpipe clearance. Turbo is a 7875 ball bearing turbonetics piece. ![]() ![]() ![]() ![]() ![]() ![]() The shortblock is still at the machine shop which is upsetting, hes taking forever but i guess it gives me time to save money, ha. I pulled the old motor out & threw it on the engine stand & then bolted on the turbo kit. I still need to throw on the p/s pump & alternator. I want to make a heat shield for the alternator & measure thermal sleeving for the power lines so I don't cook it instantly. Also I've got to measure length for oil feed & return lines. ![]() ![]() ![]() ![]() And that's really it for right now. I'll be sure to update this more as I progress. |
Recent pics after working on the new motor.
Got the new rear cover & rear main on, installed my oil pump with an improved racing pickup tube clamp & improved racing oil pan baffle. New lifters & lifter trays tossed in, got the heads torqued down with the ARP head bolts then started bolting on the front accessories & made a heat shield for the alternator. ![]() ![]() ![]() ![]() ![]() ![]() |
#5 |
#7 |
Just a bit of an update.
My new -4 a.n. fitting for the hydraulic slave showed up finally so I was able to get my clutch line & tick speed bleeder reinstalled. I didn't want to reuse my old fitting since I originally purchased it in like 2010 lol. Once I got that on I was finally able to bolt up the transmission, starter etc so now the motor is finally ready to go back into the chassis. I can't wait, there's absolutely no room to work in my bay anymore. Also, I still need to tighten down the harmonic balancer 100% but cant until the motor is in the car again because I cant lock the flywheel from spinning. ![]() ![]() ![]() I also got quoted $700 + to sandblast & ceramic coat the manifolds, crossover pipe, downpipe & turbo exhaust housing. I know it's worth it but I couldn't get myself to spend that money soooooo, I decided to make a cheap sandblast booth with stuff I had laying around. Alot cheaper than a Harbor Freight sandblast booth too. ![]() ![]() I havent finished doing everything but I started my pass. side manifold to check out how it works & it aint too bad if I say so myself. I included a picture of my driver side manifold to give you a reference of what the pass. manifold looked like before. I'll be coating the manifolds with Cerakote automotive air cure ceramic coating since I dont have an oven to bake the stuff in. ![]() ![]() |
#8 |
Haven't updated this thread in a while, figured I would. The car is just about ready for me to try & turn it over for the first.
I got Cerakote's air cure coating since I didnt have an oven to bake everything in. Let me tell you, people weren't lying when they say this stuff smelllllssss. WEAR A MASK! ![]() My make-shift rack to hold everything & the finished product + some accidental scuffs from my rack falling over....go figure haha. ![]() ![]() As of last night I finally have the turbo kit heat wrapped also & bolted up, injectors in, wiring harness all hooked up, oil feed/ return line routed, waste gate & dump tube in, belts on, radiator back in, power steering cooler installed, water pump heat ports blocked. I also tapped the top of the water pump for the steam vent tube since thatch the highest point in my cooling system. ![]() ![]() ![]() ![]() ![]() ![]() ![]() I still have a a few little things to do to the car before I try to start it. Mount my boost controller solenoid, wire up the gauges for the wideband & boost controller, bleed the clutch, make a mount for my dipstick so it doesn't pop out etc. Hopefully my next update I'll have the car running! |
#10 |
The old Daft Innovations mounting kit from about 8 years ago. Got everything just before his customer service went to complete shit. I wish I would have saved up more & just got the Sikky kit.
Just waiting on a reply from my tuner now to see when he can swing by & get a base map loaded onto my ECU so I can finally start this thing. ![]() |
#11 |
Yea I feel you there...Im running the CX racing kit since I got it for a huge steal. I've redesigned the engine mounts and had to modify some other items for fitment. Saying its "tight" is a complete understatement lol. Yours on the other hand looks like it fits nice. If I get the pleasure of building another S14/LSx swap I will be using Sikky all the way. Love the AC set up! are those Sikky as well?
#12 | |
AC wise its a mixture of the Nissan & GM a/c lines all customized to fit. OEM Nissan condenser & drier. |
#15 |
I guess 8 months later an update is warranted
moved out of my old warehouse & into a new one. So much more room to work on the cars & finally have a lift. ![]() ![]() ![]() Finally fitting my garage defend style cooling panel I've had laying around for years ![]() ![]() This past week since the car finally had a few things sorted out, I decided to finally tackle upgrading the fuel system. dual Walbro 450 e85 pumps, new rails, FPR, inline fuel filter w/ a 6 micron ethanol filter, e85 fuel lines etc. I didnt feel like spending $400+ on the PHR fuel hat which doesnt have a hanger or the $850+ setup from this shop in Australia so I decided to make the dual pump setup myself with -8 feed & -6 return. I also ordered the Radium venturi valve so I didnt have any pressure build up modding the old crappy plastic valve we have in our cars stock. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Today i'm going to be finishing up the wiring for the new relays. Going to be wiring in a 4psi pressure switch for the 2nd pump that way they both aren't running constantly. ![]() |
#16 |
I went Saturday morning to get tuned finally, couldnt figure out how to embed a video from my IG account so the link is below.
https://instagram.fmia1-1.fna.fbcdn....40652032_n.mp4 I really need to add a resonator though because now it sounds like I drive a Silverado with a 40 series flowmaster muffler haha Also need bigger injectors if I want to get more power too. 675whp on 15psi isnt too bad though. We ended up turning the boost down just a bit so I wasnt maxxing out the injectors. Also went out to Cars n Coffee WPB Sunday with some people. ![]() **wow, sorry about the image sized, used a different site because Imgur was giving me issues & it didnt have a resize option** |
