Old 02-15-2018, 05:04 PM   #1
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
KA Pressure in head, heavy smoke from exhaust
Hey guys, I'm having a weird issue.
The motor setup is an s13 KADE. It is freshly rebuilt with Ross 8.5:1 pistons, eagle rods, fresh bearings, etc. The block was bored over and the rings were filed to Ross's spec. I have put maybe 100 miles on it and it drives great, but last night it started smoking heavily. It's very clearly oil that I smell. Keep in mind I did do some break in pulls, but due to a slipping clutch I don't think the motor has seen more than 4psi, it has mostly been cruising around in traffic. My PCV valve is setup with the pcv and valve cover vent both running to a catch can, and then a hose from the catch can running to the pre-turbo intake with an air/oil separator in line. I am also using an s13 SR pcv in place of the stock one since they are known to leak. The head is all stock. I had bent the valves when my timing chain guide broke so I put the valves from my spare s14 head into it. When I did this I relapped them well and pushed supertech valve stem seals on. I also feel it is important to note that the motor feels good while driving. The AFR's are around 14.7 while cruising and it isn't sluggish by any means. The coolant temp sits right around 165F. I haven't driven the car today but last night I only saw smoke at idle and decel. While driving there was no smoke.
Today I was messing with it, and after it was running for a few minutes I took the oil cap off. There was a burst of air that came out, similar to if you unplug the hose from an air compressor, but not that kind of pressure if that makes sense. I noticed that if I put it back in and pulled it right back off it didn't do it, but if I left it on for a minute pressure had built back up. So I'm suspecting it's something in the pcv system. To avoid oil slinging out on to the turbo manifold, I pulled the hose off the valve cover port. I noticed that when I had this off the smoke pretty much went away at the exhaust. There was also constant air coming from the port, and if I plugged it a little smoke would come from the hose I had taken off.
I know the first thing anyone is going to say is rings. While I'm sure anything is possible, I don't think that's the case. My first thought was a valve seal didn't get put in right, but after finding that there's constant pressure in the head, I don't suspect that. I'm going to start by putting in a new pcv valve. From there, I'm looking for suggestions. I really don't want to blow this freshly built motor up. My savings is already struggling.
